new box verses old box - Car Audio Classifieds!
Old 07-29-2011, 12:26 AM
0/11 sssss1237
Default new box verses old box
old config was SAZ 3000d sundown @ 2 0hm producing 1600watts
2 american bass vfl 15s in a 4.5 cu ft side ported enclosure
new enclosure was aero port design, i went big this time to try spl more, same amp wired at 2 ohm
with 2 mmatts juggarnauts in a 4.75 cu ft box with 2 4" aero ports
the only thing is, the juggarnauts should be louder but they sound quieter than the 15s did, any suggestions why?
Old 07-29-2011, 01:21 AM
Bigger box? If MMATS had decided to release any t/s parameters things would be a lot easier. Hopefully some other Jugg owners will chime in on what has worked for them. Good luck.
Old 07-29-2011, 04:32 PM
0/11 sssss1237
i pretty much made the box as big as it can go to their websites specifications of 2.5cuft per sub and 60sq in of port but i used aero ports so i have 50 sq in of port instead.
Old 07-29-2011, 04:36 PM
Pioneer~Saturn's Avatar
Idk what Im talking about
0/11 sssss8346
Pics of old and new?
I assume the juggs aren't 15's by the sound of your post...?
Louder. Lower.
Team Tupperware
Old 07-29-2011, 06:44 PM
HACKMUNCH's Avatar
0/11 sssss3892
what frequency were the ports in both box tuned to?
TEAM TSA 2013
FACTORY BACKED
XS POWER - 4XSPOWER.COM
PSI - PSICARAUDIO.COM
Old 07-29-2011, 06:46 PM
ltr450racer690's Avatar
0/11 sssss3414
need more PORT
AUDIOTECHIX DEALER
DLP CUSTOMS SALES REP
Old 07-29-2011, 06:58 PM
0/11 sssss8346
Originally Posted by ltr450racer690 View Post
need more PORT
This
Louder. Lower.
Team Tupperware
Old 07-29-2011, 09:24 PM
0/11 sssssss25
2 4" aero's is only 25 sq in of port, you need 4 4" aero's for 50 sq in.
Old 07-30-2011, 09:33 AM
0/11 sssss1237
how is that only 25 sq in?
box is 5.15 cu ft. - .40 cu ft for subs = 4.75
3.14 * 4 *4 = 50.25 sq in
for the two 4" aero ports.... how is this 25 sq in?
50/4.75 = 10.57 and i thought the rule for aero ports was to stay between 7 and 12.? like slot ports are 12 and 16...
Old 07-30-2011, 11:00 AM
HACKMUNCH's Avatar
0/11 sssss3892
pie x radius squared. 4" dia port is 2x2x3.1462=12.58 sq"
TEAM TSA 2013
FACTORY BACKED
Box to specs or universal box? Would I hear a difference? theloganman General Car Audio Discussion & Questions 10 06-26-2011 08:36 PM
Dave the Box Guy Sub box for 2 15's 7'^3 @ 42hz for SUV 80$ OBO New England area hispls Wiring, Electrical & Other Installation Equipment 8 05-21-2011 01:43 AM
