is this a bad idea? - Car Audio Classifieds!
Old 07-29-2011, 01:29 AM
hdman87's Avatar
0/11 ssssss939
Default is this a bad idea?
got a 98 crown vic pi with 135 amp alt and red top optima. I was wondering could i add a xs d3400 in the trunk with the red top in front?
Old 07-29-2011, 01:32 AM
JMoney18's Avatar
0/11 sssss1577
i'd run an extra battery or 2.. never hurts to have an extra. Thts a lot of power so you'd probably need an extra batt
Old 07-29-2011, 01:34 AM
hdman87's Avatar
0/11 ssssss939
i meant can i add a xs power d3400 battery with the red top optima?
Old 07-29-2011, 01:36 AM
JMoney18's Avatar
0/11 sssss1577
Ohh, totally missed that. Well i'm not an expert by any means but I don't see why you wouldn't be able to? As long as you hook everything up correctly I don't see it being an issue.. i'm sure others will add to this thread though
Old 07-29-2011, 06:14 AM
AllenH427's Avatar
0/11 ssssss841
Red tops are AGM so yes you can.
Edit* The Red Top is more of a heavy duty battery though and is not the best battery for car audio by any means. If I were you, I'd put the biggest XS you can fit under the hood, then stick a D3100 in the back then you'll be good for a 4kw system.
TEAM XS - MECHMAN - FI - AUDIOQUE
152.6 OUTLAW AND CLIMBING
Old 07-29-2011, 10:21 AM
0/11 sssss1016
The 3400 and the red top are made up of different chemistry and can lead to issues down the road.
The D6500 will fit under the hood and work great for you. Some people have mixed batteries and it has worked for them, so it is up to you.
'1.888.497.7693 x1211
Old 07-29-2011, 11:18 AM
hdman87's Avatar
0/11 ssssss939
So I can run the D6500 under the hood with nothing in the back?
Old 07-29-2011, 12:54 PM
98AckCL23's Avatar
0/11 sssss9929
The D6500 will support up to 3kws as a starting battery. You'll be fine...
Team Concepts
Team Shok
Ohio Bass Society
Team XS Power
Old 07-29-2011, 01:19 PM
hdman87's Avatar
0/11 ssssss939
Okay cool because I got a db drive 2k
Old 08-03-2011, 07:00 AM
NESPL's Avatar
CACO Promoter
0/11 ssssss298
I had a D6500 under the hood with a 2500 watt amp and had no issues, then I added a couple of D3100's.
2005 Astro, (4) DC 18" XL's, Hifonics Sampson ~ 157.7 So far
Bad idea to drop in and say hello to a company? mattintc10 General Car Audio Discussion & Questions 25 04-03-2011 01:38 AM
good or bad idea to use this battery arntsmag General Car Audio Discussion & Questions 1 07-21-2010 10:02 PM
Good idea or Bad idea? Ccab81 General Car Audio Discussion & Questions 6 02-16-2010 06:31 PM
Fully sealed... A bad idea? altendky General Car Audio Discussion & Questions 19 09-14-2009 09:35 PM
ebay pit bike...bad idea? allout13 Off Topic Chat 15 08-03-2009 04:45 PM
