1500 watts. one 12 or two 12's? - Car Audio Classifieds!
Old 07-29-2011, 04:03 PM
doug118's Avatar
0/11 sssss4674
Default 1500 watts. one 12 or two 12's?
Currently I have 2 SA-12's on 1500 watts. If I take one of the subs out and put the full 1500 watts to the other, will there be a big difference in loudness?? I know more cone area the better but I'd be running double the power to the single sub
Old 07-29-2011, 04:06 PM
Zooook's Avatar
1337 M3mb3r
0/11 sssss3991
Feedback Score: 31 reviews
Keep running both 12s.
ALL FOR SALE ALL FOR SALE PM ME FOR PRICES
2003 BMW 330I
2x12" AB HD/W DC XL recones
Old 07-29-2011, 06:35 PM
crownvicon26's's Avatar
0/11 sssss1882
X2. Why not put more power to both subs?
Taramps 8k
2 Zv.3 15's
2.87:1 4th Order @ 48hz
Old 07-29-2011, 06:46 PM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
if you have the funds i would say to go with a single sa nightshade and throw all the power at it. a friend of mine hits 147db in his s-10 throwing 800 watts to his single sa 8" his box is not pretty but it works.
Old 07-29-2011, 07:11 PM
doug118's Avatar
0/11 sssss4674
All of my funds are going towards making the car sit flat on the ground.
I'm looking to make some room in my trunk because a 4ft^ box and 2 group 31 batteries leaves enough room for a backback and a football and KILLS my gas mileage. I'd be really happy if I could get rid of one of the 3 batteries and shrink the box down less then half the size while staying close to the same output
Old 07-29-2011, 07:36 PM
Zooook's Avatar
1337 M3mb3r
0/11 sssss3991
get rid of the 3 batts and upgrade your front batt to a XS and just put one other XS batt in the trunk and a HO Alt. save a lot of weight!! and upgrade more power and strink the box down or make subs into 10s and the box can be 2cf and use aeros and birch wood to help with weight and size! easy fix.
2003 BMW 330I
Old 07-29-2011, 08:26 PM
doug118's Avatar
0/11 sssss4674
all of which requires spending a good amount of money. my front battery is a group 31 and I have 2 more in the trunk along with a 140amp alt. as of right now my voltage NEVER drops below 13.6. I'm going to pull 1 battery out tomorrow and how the voltage does.
If I rebuild the box for one 12 I will probably go with birch.
Old 07-29-2011, 08:36 PM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
sounds like you are on the right track.
Old 07-29-2011, 08:58 PM
SpeedEuphoria's Avatar
0/11 ssssss151
deff dont need 3 batts, 2 is plenty and 1 is prob fine also
Just redo the box to something like mine, 3.3ft single 6" aero out of araucoply, it sounds nice w/ my sa12's
'03 Dodge Stratus Coupe
'89 Dodge Spirit soon to run 10's
Old 07-29-2011, 10:36 PM
doug118's Avatar
0/11 sssss4674
I think I'm going to take out 1 battery and 1 sub for a little while. will a 4th order make up for the loss of 1 sub?
1500 watts too much on SA-12? doug118 General Car Audio Discussion & Questions 7 05-30-2011 10:24 PM
dd 1500 series 2000 watts? trunk hit hard like kimbo General Car Audio Discussion & Questions 3 04-03-2011 10:46 PM
WTB Amp 1500-2000 watts Bhs2010 Wanting to Buy (WTB) 22 03-04-2011 12:29 AM
1500 watts rms at least @ 2ohms rachidfunaki Wanting to Buy (WTB) 4 08-26-2010 11:23 PM
need 1500 watts at 2ohm, which soundigital? 98Expo General Car Audio Discussion & Questions 0 05-20-2010 02:14 PM
