system metered today on termlab - Car Audio Classifieds!
Old 07-29-2011, 11:32 PM
cav950015s's Avatar
0/11 ssssss745
Default system metered today on termlab
I got my system metered today by tenbux1970 and it did pretty decent.141.7 at 37 hrz in the trunk car sealed up dropping to11.4 volts.system consist of two mtx9515s,in custom box subs face up and port faces rear tuned to 40 hrz.amp is orion xtrpro2400 at 1ohm,two big deka 100ah batteries,and three runs of zero front to back plus big 3 done.
Old 07-29-2011, 11:34 PM
thegreatestpenn's Avatar
lazy genius
0/11 sssss2592
Feedback Score: 25 reviews
decent score, but something's wrong if u peaking at 37hz but tuned to 40hz. There's probably a lot more potential in your equipment
MECA spl and sql judge
termleezy fo-sheezy
Old 07-29-2011, 11:36 PM
R/T Pimp's Avatar
0/11 ssssss357
Unless he is using areo ports.
Team Gorilla
President and Co-Founder
Team Treo
Only the Best
The 2 best sentences you will ever read:
What one person receives without working for, another person must work hard for without receiving.
The government cannot give to anybody anything that the governmnet does not first take from somebody else.
Old 07-29-2011, 11:37 PM
0/11 sssss1898
He has 2updated dekas and only 1 2400 watt amp and still dropping to 11.4 something is wrong there.
2002 suburban
Security System
Code alarm
Electrical
Dc power sp270 7 deka 9A31's and lots of 1/0
Headunit
pioneer 880prs
Amps
Sax125.2 front stage 2 Saz-4500's [email protected] 1 ohm
Wiring
lots of 1/0 stinger, tsunami
Mids & Tweeters
Dd w6.5 mids and lanzar opti crossovers and tweets
Subs
4-18" nightshade v2's d2
System Details
Daily driver.
Old 07-29-2011, 11:38 PM
cav950015s's Avatar
0/11 ssssss745
Yeah its called stock alt lol
Old 07-29-2011, 11:42 PM
lazy genius
0/11 sssss2592
nah, cause the batts should discharge enough power needed before the alt has to recharge them/provide power. How's your grounds?
termleezy fo-sheezy
Old 07-29-2011, 11:47 PM
cav950015s's Avatar
0/11 ssssss745
Everything is tight and and clean battery under hood is a everstart that is kind of old and I noticed its leaking a lil so might be that
Old 07-30-2011, 07:50 AM
More spl's Avatar
0/11 sssss2638
Feedback Score: 29 reviews
He has three runs of zero front to back big three done. It discharges and it takes time for that little alt to try to charge. Also the amp is 2 ohm stable it's being ran at 1ohm. His alt is 7 years old He also needs to charge his batts do to running them for extended periods with out charging. His car is a trunk car and most trunk cars peak in the 30s.If you aise his rpms to 3 grand it drops to 12.1.
this how I feel about audio
http://www.youtube.com/watch?v=8th2J3c88mU
Old 07-30-2011, 07:54 AM
More spl's Avatar
0/11 sssss2638
He has a run of zero from front to back as the ground his 1st batt has a 0 and a 8 gauge ground the batts are grounded to each other in the back and grounded off the main ground.
Old 07-30-2011, 08:11 AM
0/11 ssssss340
there is way more potential in that setup...I've only got 2 c&d batteries on a 60A (max) alt 1 run of 1/0 to the back battery, back battery grounded in the back. Sundown 3k on a RE HC 15 @ 1 ohm (set at 2000w using DMM) voltage only drops to 12.5v at idle. haven't metered it yet but know its definitely doing more than a 141.7.
Cabin gain is what explains peaking lower than the box is tuned to.
got metered today =D 20Hz_And_Below General Car Audio Discussion & Questions 6 02-20-2011 08:07 PM
Well I metered today..... 87linkin General Car Audio Discussion & Questions 11 07-23-2010 04:00 AM
Metered today... strpperpolef150 Off Topic Chat 20 01-09-2010 05:50 PM
Got metered today... Andrew Off Topic Chat 42 07-31-2009 02:06 PM
Getting Metered Today NoPh33rRaCiNg Competition Corner 13 04-19-2009 05:37 PM
