The big 3 - Car Audio Classifieds!
Old 07-30-2011, 11:22 PM
0/11 ssssss928
Default The big 3
i have seen alot of people here and on you tube talk about the big 3. my question is when is it necessary to do the big 3. it just seem that if you dont change the battery and get a bigger alt. that your just wasting your time. im not sayin that this is not a good thing to do.i just wonder when should we do it. please people dont bash just give me a lil info.
Old 07-31-2011, 12:14 AM
massivespl's Avatar
0/11 sssss8409
having more and better grounds and having a 0 gauge wire running from your alt to your batt is a good idea even if its a stock alt and stock batt. but if your not having voltage drop then you prly dont have to do the big 3 but i dont see why you wouldnt want to.
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 07-31-2011, 12:29 AM
Unleash The Beast
0/11 ssssss245
The bigger the wire the less resistance. Also as cars age the stock ground wires, and power wires start to degrade. Its always a good Idea to do the big three. Personally if your putting a system in your car I would do it. It could very well reduce, or eliminate your voltage drop/ lights dimming depending on how big of a amplifier your installing.
Check out my ride
Did I help you out?
Don't forget to hit thanks ------->
The Big 3 RWatts General Car Audio Discussion & Questions 2 07-06-2011 04:35 PM
cheap cone area vs. big power big subs nicyousuckk General Car Audio Discussion & Questions 21 02-15-2011 02:18 AM
Big Big question, need help... masterbarber General Car Audio Discussion & Questions 31 10-13-2010 09:12 PM
big 3 my_son_is_my_life General Car Audio Discussion & Questions 3 12-15-2009 01:13 PM
