02 Acura tl trunk - Car Audio Classifieds!
Old 07-31-2011, 03:25 PM
0/11 sssssss56
Default 02 Acura tl trunk
Anyone have experience with this car? I've run many different setups buts always sub and port back. Back seat does not fold down, only the arm rest does opening up maybe a 5"x 11" opening. Also a hole in the rear deck where the stock sub used to be. I'm gonna build a box for a single 15 and was thinking of trying sub up port to the side. Any recommendations?
Old 07-31-2011, 03:34 PM
0/11 ssssss484
I will suggest sub forward centered on the opening . Port up to your speaker opening.
Old 07-31-2011, 04:33 PM
LEN671's Avatar
BASSHEAD from Guam!!
0/11 sssss1148
Alot of people have been doing 4th orders and porting it through their armrest. Because their backseat doesn't fold down.
Are you going for numbers or just a shake the F-ING BLOCK box for the lows.
DC LVL5 12's
3 - KINETIK HC2400
1 XSPOWER XS7500
1 - ALPINE 9886
2/0ga. WIRE THROUGHOUT
Team DC Audio 2012
Old 07-31-2011, 04:39 PM
0/11 sssssss56
I really don't compete so it's just a daily driver. I've considered a 4th order but I'd never be able to fit one for a 15 and I doubt a sig would like a bandpass. As far as sub forward and port through the rear deck I'd imagine cancelation would be pretty bad and I don't think it would work otherwise because the the sub motor would end up being in the way port. I'm starting to hate this car...
Old 07-31-2011, 08:48 PM
LEN671's Avatar
0/11 sssss1148
What kind of sub are planning on using?
DC LVL5 12's
3 - KINETIK HC2400
1 XSPOWER XS7500
1 - ALPINE 9886
Team DC Audio 2012
Old 07-31-2011, 08:50 PM
LEN671's Avatar
0/11 sssss1148
Or you could try Sub back and Port up through the rear deck.
DC LVL5 12's
3 - KINETIK HC2400
1 XSPOWER XS7500
1 - ALPINE 9886
Team DC Audio 2012
Old 07-31-2011, 08:55 PM
Ronmeister's Avatar
0/11 ssssss791
Have you had luck with a woofer centered in the opening? How far back from the opening?
Have you made any sort of "tunnel" around the woofer to the opening? I was contemplating making a deal like that, and sort of sealing it to the rear seat where the opening is.
Old 07-31-2011, 09:00 PM
0/11 ssssss484
i would just let it rip about 4inches back .the trunk open should be a gain a well
Old 07-31-2011, 10:58 PM
0/11 sssssss56
I tried a single 10" firing forward about 2 inches from the opening and a 6" aero port facing up through the rear deck but it was a tight fit. The motor of the sub was damn near touching the port. I'm using a 12" shocker sig right now but plan on rebuilding it to a 15" soon so that's the box I'll be building. I'll just have to try a few different boxes out and hope for the best.
Old 07-31-2011, 11:55 PM
0/11 ssssss118
I had my 15 sun up port back in my tl I hit a 144.4 sealed up at 40 hz.
Trunk 0-1000w Class RUN....LOUDEST TRUNK EVER Skip01 Car Audio Videos 270 04-30-2012 08:54 PM
4 door trunk car - cant use trunk ... brian84corvette Enclosure Discussion & Design Construction Help 23 10-13-2010 08:24 PM
**** acura cl s with a spiked ****. djm4rshm2llow General Car Audio Discussion & Questions 7 06-01-2010 11:38 PM
acura trunk flex and house flexx?? 808head Car Audio Videos 40 03-24-2010 11:04 AM
Acura CL trunk specs DS Autosports General Car Audio Discussion & Questions 7 02-03-2010 09:35 AM
