4 10s or 2 12s - Car Audio Classifieds!
Old 08-01-2011, 10:47 AM
statonburrell's Avatar
go big or go home
0/11 sssss1896
Default 4 10s or 2 12s
Doing a new build under the rear seat of my 2008 silverado. Getting away from ported 10s. I've got apprx 3.4 cubes. I was debating 4 10s sealed firing towards the front seats or I can fit 2 12's downfiring sealed. The 10s would either be SA 10s or PSI platform 1s. The 12s would be PSI platform 2s. Power is a sundown 3000D. Let me know your opinions.
Here's T/S specs for reference
SA 10s
Re: 4.29 ohms
Fs: 35.4 Hz
VAS: 10.13 L
Qes: 0.52
Qms: 5.41
Qts: 0.48
Le: 3.41 mH
BL: 20.40 NA
Mms: 230 g
Cms: 87.8 uM/N
Sens: 81.0 dB 1w/1m
Platform 1 10s
Revc = 5.6 ohms
Fms = 29.7 Hz
Qes = 0.53
Qms = 5.34
Qts = 0.46
Sd = 315cm^2
Vas = 34.3680 L
BL = 18.5 N/A
Sensitivity = 84.7 dB @1W/1m
Xmax = 36mm total
Usable excursion = 3" total
Platform 2 12s
Revc = 3.4 ohms
Fms = 29.3 Hz
Qes = 0.52
Qms = 5.3
Qts = 0.48
Sd = 490cm^2
Vas = 54.1 L
BL = 15.5
Mms = 198.3 g
Sensitivity = 85.8 dB @1W/1m
Sensitivity = 89.4 dB @2.83Vrms/1m
Xmax = 56mm total
"Though the road has been hard as the day is long, I wouldn’t trade in a second. The strength that’s allowed me to endure doesn’t come from what you see--the thick slabs of meat, veins thick as rope, skin so thin the grainy fibers show. No, it runs deeper. To get to it, you’d have to cut away all the layers of doubt and distraction till knife hits bone. The seconds are passing by. Find that itch... Scratch till there’s nothing left."
12s or 10s and which ones. davidrforbus General Car Audio Discussion & Questions 16 02-23-2011 11:07 AM
2 sa 12s or 10s thekernal123 Wanting to Buy (WTB) 5 02-09-2011 05:24 PM
SA-12s / 10s In Stock sundownz (Sundown Audio) 7 06-26-2010 09:58 PM
WTB 10s or 12s alex95sl2 Wanting to Buy (WTB) 5 06-26-2010 06:18 PM
2 12s vs 4 10s fox_racin4 General Car Audio Discussion & Questions 14 06-03-2010 08:39 PM
