A little help with mids and highs... - Car Audio Classifieds!
Old 08-01-2011, 01:28 PM
0/11 sssssss82
Default A little help with mids and highs...
Hey Guys, I'm getting ready to buy mids and highs for my sons 02 Xterra. It has 6.5 in the doors and tweeter housing on the pillar. The rear speakers are 6x9's and I'm not sure how much he will hear them because they will be in the very back with the 15's but I figure I will give them a shot and see. I will be running them all with a Crescendo 1000c4. I just need help on what to get...apparently MB Quart is no longer the shit...lol
I'm open minded as far as budget goes. Daily driver more about keeping up with the substage and still having solid SQ.
Thanks
Old 08-01-2011, 01:38 PM
groundpound4200's Avatar
Errday I'm Hustlin'
0/11 sssss1785
I ran a pair of Focal Access 165As in my 03 Xterra and they did pretty good off a Sundown SAX 100.4 active. I was also able to keep everything behind factory grills. I agree on not running the 6x9s as they will probably play right into the sub box because of their goofy location.
2007 Honda Pilot
Sundown SAZ 1500D V.3
2 Atomic APX 818 10"s
Taylor Lampart aka NewAgeKing
Old 08-01-2011, 07:59 PM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
I prefer JL for great SQ if you can afford them. But also eclipse or Soundstream also sound good. I would ditch the 6x9 and concentrate up front. With 15's they will drown out the 6x9. And if they aren't sealed they tend to be canceled out with the subs.
If anything pop a couple tweets in the rear pillar or do some 5 1/4 in the doors.
Old 08-01-2011, 08:23 PM
Matt3824's Avatar
0/11 sssss3754
If your only gonna have one set of comps to keep up with 15s then I would suggest the RE XXX comps.
mids and highs burd337 General Car Audio Discussion & Questions 1 07-31-2011 05:27 PM
need new mids and highs gettingloud15`s General Car Audio Discussion & Questions 6 02-28-2011 10:22 PM
Highs and mids? mads10bass General Car Audio Discussion & Questions 10 10-06-2010 05:22 AM
help with my mids and highs murderedtahoe General Car Audio Discussion & Questions 6 07-04-2010 10:34 AM
mids and highs natisfynest General Car Audio Discussion & Questions 16 01-23-2009 11:47 AM
