Line drivers - TRU vs ARC... Or where did my bass go? - Car Audio Classifieds!
Old 08-02-2011, 01:08 PM
0/11 ssssss468
Default Line drivers - TRU vs ARC... Or where did my bass go?
So before i installed my Arc IDX and XEQ i used Tru SSLD6i to boost my voltage.
SSLD6i is adjustable (non-balanced) voltage driver where each channel can be adjusted to user's liking/system's requirement and ARC's IDX and XEQ while aren't technically line drivers (one is active x-over and other is eq) both have 8V output.
One “negative” thing I’ve noticed as soon as I replaced TRU with ARC combo is that my Polk Audio SR5250 woofer wasn’t as “bass-y” as it used to be. It sounds great, has decent midbass but before this swap it was more of a subwoofer. I swear, I’ve NEVER in my life heard any 5.25’’ woofer play 60-80Hz with such an authority at any volumes. After over a month now of every day tuning (since I went active as opposed to previous bi-amped setup) and playing with different things I can’t help but think of my SSLD6i as a “missing piece”.
Logic behind taking it out of the setup was that ARC stuff has 8v output anyways which would make my SSLD6i just a “useless piece in the chain”.
Is TRU SSLD6i really what I’m missing or is it something else I fail to see?
Old 08-02-2011, 01:25 PM
jnknzz's Avatar
0/11 ssssss190
Did the boost to 8v get the result you wanted? Unless you're getting no voltage from your HU, I guess I don't see the need for the increase.
Old 08-02-2011, 02:37 PM
0/11 ssssss468
No, Arc's 8v didn't cut it. It actually made it "worse" if you will comparing to TRU's voltage (can't say what it was since it's adjustable, no way to know for sure lol)
Old 08-02-2011, 05:00 PM
Benny33's Avatar
Hockey players, man...
0/11 sssss1616
I would look into your crossover and EQ settings. My guess is something is being cut out of the signal path.
Yous just figures that out? All the hots ones is crazy!...And deh ugly ones too. - Toki Wartooth
Old 08-02-2011, 06:08 PM
0/11 ssssss468
I thought the same till a month of daily tuning and playing with stuff. Even with most lower frequencies "boosted" by eq and higher frequencies "cut" i still can't get to that "wooof"er feeling i used to get out of my SR5250.
Just so we're on the same page - i have a good solid midbass, most people would compliment it if they heared it but i know it's nothing like it used to be. It used to sound like i have 8'' subwoofers in my doors lol.
I still think it has something to do with voltage but i don't know enought on this subject to be certain (balanced, unbalanced, getting lost via RCA....)
Line Drivers Info. budowens83 General Car Audio Discussion & Questions 0 11-08-2010 04:42 PM
Pre Amp Line Drivers? MisterGrubbs General Car Audio Discussion & Questions 1 03-29-2010 07:44 AM
Line drivers SPY General Car Audio Discussion & Questions 6 03-13-2009 11:56 AM
Tube Line Drivers... only126db General Car Audio Discussion & Questions 3 12-06-2008 12:57 PM
Line drivers forceww General Car Audio Discussion & Questions 7 08-27-2008 01:07 PM
