slot port or aero port - Car Audio Classifieds!
Old 08-02-2011, 08:57 PM
tommytee's Avatar
0/11 ssssss515
Default slot port or aero port
building a new ride.got rid of the durango and bought a 2004 tahoe.lookin at doing a wall in the third row section for the 4 18'' hdc3-a's. power will be from the 2 aq 3500's.looking aero ports or slot. box will be 20 to 25 cubic ft,basicly as big as i can go back there. doing comps and playing music. was even thinking about no wall...........i dont know?
Old 08-04-2011, 09:55 AM
AMI CUSTOMS's Avatar
SOUNDQUBED EXPERT
0/11 ssssss524
For anything over 15 cubes always run slot port I have seen no benefit once you get a box that big or larger running aero ports.
3x STREETBEAT World Record Holder
-Streetbeat 4 - 161.9 db
-Streetbeat 5 - 162.6 db
The Black Nasty (SOUNDQUBED)- 160+ db
Old 08-04-2011, 10:07 AM
0/11 ssssss445
For wallas you want to use a slot port....there's a reason you dont see aeros in walls..it's beacuse with boxes that big..slot ports are easier and better.
Old 08-07-2011, 09:17 PM
tommytee's Avatar
0/11 ssssss515
thanks guys looks like i going with the slot, i have more room to work with now. slot going to be 11'' wide 36'' tall 396''s of port for comps.will make a drop in port for daily.box is 25.5 cubic feet before displacement.how deep to make the comp port.wall is in a 2004 tahoe,behind the second seats,peak is around 48 hrtz.
aero-port vs. slot port? thumper21 General Car Audio Discussion & Questions 23 03-22-2011 11:12 AM
