Kove armageddon t3 box recommendations. - Car Audio Classifieds!
Old 08-24-2011, 02:52 PM
0/11 sssss1137
Default Kove armageddon t3 box recommendations.
Does anyone know what these woofers like? Do they do well in bandpass? Vented? Sealed? Im looking for specs to know what kind of box I need to build. I just.dont know much about em
2012 jeep wrangler unlimited
Pioneer avhx4600bt-Realm components-Focal coax-Ppi p.9004-Rd d9-2 Northstar nsb130
Old 09-06-2011, 01:58 PM
WiseguyzzInc's Avatar
0/11 ssssssss5
I have the original spec sheet from 2004 in front of me... Don't have a scanner at the moment other wise I would post the whole thing...
Do you have the 10, 12, or 15? and is it the dual 2, 4, or 6 ohm?
I'm using a vented enclosure, sloted port for my single 12" T3 Dual 2 ohm....
If you plan on buying an enclosure and not making your own, I suggest one of these...
http://www.hifisoundconnection.com/S...id/0/SFV/30046
or
Old 09-06-2011, 02:42 PM
0/11 sssss1137
Its a 15 d4. Let me know the specs please!!
Old 09-16-2011, 11:53 AM
0/11 ssssssss5
Sorry for taking forever... Heres the specs you requested
T3 15D4
Fs(Hz) = 29
Qts = .58
Qes = .64
Qms = 7.10
Vas(Lit.) = 64.00
SPL dB(2.83 v.) = 93
Xmax(mM) = 18.00
Z nom(Ohms) = 2 x 4
RMS(watts) = 1000
Mounting Depth(inches) = 9.25
Mounting Diameter(inches) = 14.00
If I get some time I'll put the whole manual in a .pdf, let me know if you need anything else...
Old 11-24-2012, 04:11 PM
Brand New Members
0/11 ssssssss2
Default kove armageddon 12" T3D2 specs
T3 15D4
Fs(Hz) = 29
Qts = .58
Qes = .64
Qms = 7.10
Vas(Lit.) = 64.00
Xmax(mM) = 18.00
Z nom(Ohms) = 2 x 4
RMS(watts) = 1000
Old 11-24-2012, 04:16 PM
Brand New Members
0/11 ssssssss2
Hi my friend,
I'm from Tahiti, frendch polynesia
I saw your posts about KOVE ARMAGEDDON T3
I'm going to build a bandpass 6th enclosure
but I don't have specs of my subwoofer
please someone can help me?
I have a kove armageddon T3 12D2
thank you
Kove armageddon 12 RYDOGG2992 General Car Audio Discussion & Questions 0 08-11-2011 10:52 AM
Kove Kove Armageddon Z series motor cheap Jason19 Speaker Accessories & Parts 21 02-04-2011 02:19 PM
Kove Armageddon 12 kr-15 (Fix My Speaker) 5 12-01-2010 12:18 PM
Kove Armageddon U2 orangelss (Fix My Speaker) 1 10-16-2010 12:25 AM
Kove Armageddon gh0st General Car Audio Discussion & Questions 33 07-19-2010 08:41 PM
