sub wiring question? - Car Audio Classifieds!
Old 08-24-2011, 04:42 PM
0/11 sssssss14
Default sub wiring question?
So I have two 8 ohm subs and I was wondering how to wire them down too 2 ohms because in order to get decent wattage out of the amp i am going to use i need to run them at two ohms. Any help would be appreciated.
Thank in advance,
KCowboy620
Old 08-24-2011, 04:59 PM
Ajax_6154's Avatar
i want more bigger db's
0/11 sssss2369
im assuming they are single voice coil? if so you wont be able to wire them to 2 ohms. best you'll get is 4 ohm
Vehicle: 2011 VW GTI Autobahn
Deadning: 50sq ft of AT 60, Front Stage: CCX65 on a 1000c4, Sub: Eminent Audio EA1000 10's in 4.9ft3 at 35hz on a BC3500d at 1ohm
i dont like 12's they cant hit the lows like 10's
Old 08-24-2011, 09:29 PM
0/11 sssssss14
Ok thanks i thought maybe there was a way and i just was not searching correctly
Old 08-24-2011, 09:33 PM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
depending on how you wire them you will get either 16 ohms or 4 ohms.
Old 08-24-2011, 10:05 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
Parallel= 4 ohms
Series= 16 ohms
You are correct
Sub wiring question d1sano General Car Audio Discussion & Questions 1 06-28-2011 11:55 AM
wiring question WhiteTB General Car Audio Discussion & Questions 4 01-31-2011 06:17 AM
RE MX Wiring question burtgtp1973 General Car Audio Discussion & Questions 6 11-04-2010 03:14 PM
Wiring question andes11 General Car Audio Discussion & Questions 9 08-24-2010 10:17 PM
question about wiring dat517boi General Car Audio Discussion & Questions 6 07-25-2010 09:38 PM
