Forevr Bumpn- call me - Car Audio Classifieds!
Old 08-25-2011, 09:57 PM
Nik592's Avatar
0/11 sssss2000
Default Forevr Bumpn- call me
hey bro cant seem to send you a message since nobody wants to fix the sites PM's
my number is 231-920-4291
got a ? about the subs that you built for Stylez12321, call me asap if you can and if anyone sees this and knows him please have em give me a call asap
thanks alot and sorry to put something ridiculous in this section
but seeing as how PM's ALWAYS get that error.....
"Insert witty signature here"
Old 08-26-2011, 06:15 AM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
What is your question? Maybe I can help.
Old 08-26-2011, 07:41 AM
Nik592's Avatar
0/11 sssss2000
Thanks bro I hope so
I got two of those 12's from stylez12321 with the type R motors and baskets and the new softparts, my problem is when I connect them to my amp I can barely get either one to move an their fairly quiet unless I crank the volume up to 30 or so (this is free air but I know my limitations on it as well so I don't go too hard!)
When I reach volume 30 or so the sub will start to (excur?)
Alot more like it should and I can tell it's louder but right about then is when it starts to spark? it looks like it sparks right at the leads, or at the tinsels or something!
and then I shut it down really quickly, it also wil have a burning smell but the sub will still play fine and still is super stiff on the suspension
JP (stylez) said the tinsels are super conductive and need to be heat wrapped and that's prObably whats causing it, does that sound about right? Or do I have a different problem here? Thanks in advance
Old 08-26-2011, 02:04 PM
Ja Marcus
0/11 sssss6975
The cones used for those re-cones were old PG Xmax cones. They are made from true carbon fiber(which is conductive) if the leads touch the cone THE WILL ARC! Trust me I blew 2 small holes in the ones I had back in the day. I couldn't figure out for the life of me what caused it till I pulled the sub and relized it was exactly were the leads were. I ended up heat shrinking them and had no problem afterwords.
As for output. I"m no tsure on that one. The re-cones were paralleled at the coil. Since the Alpine basket has the leads on one side foreverbumpin chose to wire them in parallel to make it easire for the leads to be attached to the basket. So essentially they are single 2 ohm VC's.
Do you have a meter to put on and check the resistance?
Old 08-26-2011, 02:12 PM
Nik592's Avatar
0/11 sssss2000
Ok I just bought heat shrink tubes to wrap the leads or tinsels up, hopefully that takes care of that
Now for resistance, I DO have a dmm
Is that all I need?
and how do I check it exactly just put the pos in the pos and neg into neg lead?
Old 08-26-2011, 02:58 PM
Ja Marcus
0/11 sssss6975
It doesn't matter which lead goes to which terminal. Just set the meter to read Ohm's and see what they come out to. It should be right around 2 ohms maybe slightly more. If you have anymore questions shoot me a PM. Mine should be working.
Old 08-26-2011, 04:38 PM
Nik592's Avatar
0/11 sssss2000
ok thanks man
I would call this my best yet jt_buck General Car Audio Discussion & Questions 11 05-30-2011 09:20 AM
call out... RXZILLA Competition Corner 0 04-10-2011 05:57 PM
call me old fashioned korey_hofer Off Topic Chat 35 08-24-2010 08:15 AM
Would you call this 8 gauge? csu87 General Car Audio Discussion & Questions 30 01-09-2010 02:37 PM
A Call out to CACO for some help 98AckCL23 Off Topic Chat 114 10-17-2009 07:36 AM
