design request for t.hybrid [Completed] - Car Audio Classifieds!
Old 08-26-2011, 08:54 AM
0/11 ssssss210
Default design request for t.hybrid [Completed]
Design request for :t.hyrbid
Subwoofer/speaker brand: digital design
Subwoofer/speaker model, size, and number of woofers: 3512, 12", 2
Expected power handling: aq3500.1
Vehicle enclosure will be used in: car, honda fit 2010
Max dimensions : 23h, 40w, 14d
Listening expectations (description): sql
What bandwidth is acceptable? 35-60hz high output, 30-80hz? 28hz - 55hz
How low do you want it to play and how important are the low notes (Song examples are encouraged)?
i love the lows and electronics music kinda david guetta songs, pitbull
Are you looking for a heavy low end, or one that blends with the rest of the output?
both if you can.
How important is sound quality compared to loudness?
mix of both, i mean i like it loud and to sound good
Are you able to cut odd angles? (45*, 7*..)
just between 25-75 angles
Is this an SPL design? If so, what is your peak frequency? If you do not know this, please measure your average cabin length in inches!
no, this isnt.
Any specific enclosure preferences (Double baffled, flush mount, center slot, blowthrough, home environment etc)?
it doesnt matter, i wanna a amaizing design for my setup.
Other notes:
Old 08-26-2011, 01:39 PM
surreal's Avatar
0/11 sssss2489
Are you sure you can not cut angles less than 25*? Most table saws can cut 0-45*
Also, is 14 deep your max depth? Or does that leave room behind the enclosure for a possible port?
Old 08-26-2011, 09:01 PM
0/11 ssssss210
ok, i can cut any angle
yes, 14 is my max depth, because i wanna put the box with the sub face up, do you know what I mean? like this picture:
Uploaded with ImageShack.us
Old 08-26-2011, 10:35 PM
surreal's Avatar
0/11 sssss2489
Sure do, just making sure.
I need confirmation on the smaller angles. Are you able to cut like a 7* angle for example? For reference, most all table saws can do so.
Edit - Nevermind, saw your response within my quote!
Old 08-27-2011, 01:11 AM
surreal's Avatar
0/11 sssss2489
Design has been completed and can be found/purchased here: 2x3512s Ported - $15.00 : TheBoxHouse, Enclosure designs
A ported enclosure was chosen as best due to need of power handling, working dimensions and restriction type within the rear hatch area. A t-line would have been a possibility, though firing down into the bottom seat area wouldnt have been the best choice.
This should fit your cabin quite well, enjoy!
Box request for kingtidis [Completed] kingtidis General Car Audio Discussion & Questions 11 10-27-2011 08:33 PM
Design request for 3rdshift [Completed] 3rdshiftdiscretion General Car Audio Discussion & Questions 3 08-26-2011 12:36 AM
design request [Completed] darkkon General Car Audio Discussion & Questions 7 08-25-2011 09:07 PM
Box request for t.hybrid t.hybrid Box Requests 1 08-25-2011 12:24 PM
Box design for 03tbls [Completed] 03tbls General Car Audio Discussion & Questions 13 08-24-2011 04:58 PM
