AQHDC318 open coil - Car Audio Classifieds!
Old 08-26-2011, 11:03 AM
D810boy's Avatar
0/11 ssssss600
Default AQHDC318 open coil
one of my hdc318 has an open coil.(not reading ohms)
its a D2 copper coil. one side reads 2.1 ohms, the other side is O.L..
i even tried reading it @ the leads and still open line. it doesnt smell burnt or anything. i pulled out the cone and tried to meter the coil under the spider pack near the triple joint and still no ohms. kinda wierd cuz the coils look brand new still, no burnt smell or discoloration. anyone had this problem?
GROUND&POUND
Old 08-26-2011, 11:07 AM
groundpound4200's Avatar
Errday I'm Hustlin'
0/11 sssss1785
hook each coil up to the amp independently to see if it plays or not. If it doesn't play on one side you may have shredded the tinsel leads in the spider pack.
2007 Honda Pilot
Sundown SAZ 1500D V.3
2 Atomic APX 818 10"s
Taylor Lampart aka NewAgeKing
Old 08-26-2011, 11:17 AM
D810boy's Avatar
0/11 ssssss600
my leads are on top the spider pack
GROUND&POUND
Old 08-26-2011, 11:21 AM
Errday I'm Hustlin'
0/11 sssss1785
hmm... must have burnt under the dust cap then near the triple joint. You might be able to fix it if you pull the cap off
2007 Honda Pilot
Old 08-26-2011, 05:54 PM
hawaiianmaxx's Avatar
0/11 ssssss862
Something similar happened to one of my Nightshades. I couldn't tell until I cut it up. A pair of wires coming up the former from the coil burnt open(like popping a fuse) right bellow the spider pack.
KIDS SAY THE DARNDEST THINGS-
STOP PAYING ATTENTION TO YOUR RATIO IN 4TH ORDERS!!!! Ratios in 4th orders mean about as much of the color of socks you wear.
I never said getting 60 MUSICALLY will be easy did I? Getting 60+ on a burp machine is, sorry to say that but it is.
Old 08-31-2011, 11:19 AM
blazin20s's Avatar
0/11 ssssss334
Id call dj or josh and ask them cuz I got 2 of them were the. Coils were unwinding at the top....?
18'' hdc3 copper coil and alimunum coil Fosgate1 General Car Audio Discussion & Questions 2 06-05-2011 03:15 PM
Elevation EXE motor and a 3" Round aluminum TC coil, D.5, coil can easily handle 2k R Novicaine Car Audio Packages 7 05-04-2011 09:59 PM
FS:GIANT 4" coil. real big coil. Violence* Speaker Accessories & Parts 8 03-10-2011 10:50 AM
------open me--------- MeLykeLotion New Member Orientation 7 02-01-2010 07:31 AM
