Impedance Question - Car Audio Classifieds!
Old 08-26-2011, 02:30 PM
gti1.8t's Avatar
0/11 ssssss361
Default Impedance Question
Sorry for the dumb question... would anyone know off the top of their head what a single 6 ohm wired to a single 2 ohm would make for a final nominal load?
Thanks!
Purchased from: dbass,
Old 08-26-2011, 02:35 PM
Prohibited Sellers/Buyers
0/11 sssss1285
why are you wiring two different ohm'ed speakers?
Old 08-26-2011, 02:37 PM
gti1.8t's Avatar
0/11 ssssss361
for my interior speakers... i'd like to try n run a set of coax's from JBL in the rear and also a set of tweeters (with their own crossovers).
side note.. i already have the tweeters laying around, and the JBL's i can get for dirt cheap through a buddy.
Old 08-26-2011, 02:38 PM
0/11 sssss1285
is it a two channel or four channel?
Old 08-26-2011, 02:40 PM
gti1.8t's Avatar
0/11 ssssss361
4 channel, but i also want to run a front stage as well and have keep the rears as just a filler. Running off a JBL 1004
Old 08-26-2011, 02:44 PM
0/11 sssss1285
does the cross over for the have a mid out put? I'm not sure how well it going to sound because if you set your amp crossover to run your coax as mids than I'm not sure how well your tweets will sound with a limited signal from the amp.
Old 08-26-2011, 02:45 PM
gti1.8t's Avatar
0/11 ssssss361
What I plan on doing is running the tweeters through the crossover then run wires from the coax to the amp and splice them @ the amp. The coax are also made by JBL (2-way)
I just wanna be sure I'll be okay on the amp splicing a 2 ohm and 6 ohm together
Old 08-26-2011, 02:51 PM
0/11 sssss1285
I'm sure it would "ok"... just not ideal!
Old 08-26-2011, 02:52 PM
gti1.8t's Avatar
0/11 ssssss361
lol fair enough :P any idea what the final impedance would be?
Old 08-26-2011, 02:56 PM
0/11 sssss1285
I would think either 2ish or 8ish depending on the way you wire them...
What Impedance Sub?? EARmeBump General Car Audio Discussion & Questions 3 07-17-2011 11:11 AM
Question about coil impedance OldSchoolRF General Car Audio Discussion & Questions 3 07-06-2011 10:51 AM
Impedance and Wiring Question andes11 General Car Audio Discussion & Questions 9 05-30-2011 02:43 PM
3 Sub Impedance Question Dutchie. General Car Audio Discussion & Questions 13 02-28-2011 07:46 PM
question about impedance rise Craig28 General Car Audio Discussion & Questions 11 07-16-2010 02:54 PM
