hdc3 15'' bad coil help. - Car Audio Classifieds!
Old 08-26-2011, 09:24 PM
0/11 ssssss259
Default hdc3 15'' bad coil help.
Ok I did a recone on my sub about a week ago and did some free air on the sub to break it in. Free air was at minumal power to get this stiff suspension to get it some what loose so I free air it for about 6 hrs on test tones from 35-30 hz.After that I went ahead and put it in a box that was tune to 38hz box was about 4.5 cuft. played it for about 5 days with minumal power somthing like 500-600watts after the 5th day it started poping i was like wtf. so i took out the sub to check it out and played it free air and see where the noise was coming from. couldnt figure it out sound like it was coming from the dust cap. . so then i check out the spiders see if they were torn ripped ect.. nothing they look good to me. so i just decided to take it out the recone so what i seen was the coil seems like it shifted it will show all in the pic. Is this normal please let me know i sent these same pics to aq. . please let me know if the fromer and the coil should be like that and if its normal.
Old 08-26-2011, 09:40 PM
bigdhenderson's Avatar
0/11 sssss4981
Feedback Score: 45 reviews
well your problem was that you free-aired it....DJ told me that any amount of free air playing will wreck the sub....
Old 08-26-2011, 09:47 PM
0/11 ssssss259
micheal told me from aq told me that it was fine i free air it like with 300 watts if that.
Old 08-26-2011, 09:50 PM
0/11 sssss4981
Is the coil loose on it? can you move it around?
Old 08-26-2011, 10:12 PM
0/11 ssssss259
no it doesnt but that doesnt look normal right?
Old 08-26-2011, 10:17 PM
Kingdom of Solitude
0/11 sssss1254
Looks like slight rubbing when you reconed did you shim. If so with what
Youtube Channel
Old 08-26-2011, 10:33 PM
AMI CUSTOMS's Avatar
SOUNDQUBED EXPERT
0/11 ssssss524
Looks like coil rub, former looks fine me. Either you reconed it off center or there was something in the magnet that didn't get removed and rubbed on the coil.
3x STREETBEAT World Record Holder
-Streetbeat 4 - 161.9 db
-Streetbeat 5 - 162.6 db
The Black Nasty (SOUNDQUBED)- 160+ db
Old 08-26-2011, 10:35 PM
SOUNDQUBED EXPERT
0/11 ssssss524
I find that hard to believe. Free air won't wreck a sub, unless you unload the hell out of it, which is easy to do if you got some power behind it.
Old 08-26-2011, 10:37 PM
0/11 sssss4981
Im not even kidding about that. He told me free-airing will ruin it every time (especially if you have the pole vent blocked, even with the dust cap off) and if you do have to free air it not to put more than 100 watts to it. Im dead serious.
Old 08-26-2011, 10:38 PM
Kingdom of Solitude
0/11 sssss1254
yea what did you shim the coil with i hope you didnt use them flimsy ass plastic sheets that come with the kit.
Youtube Channel
18'' hdc3 copper coil and alimunum coil Fosgate1 General Car Audio Discussion & Questions 2 06-05-2011 03:15 PM
AQ HDC3 15''. installation help jgutierrez General Car Audio Discussion & Questions 8 09-06-2010 02:26 PM
[NLFS] 05 RE XXX15, bad coil 1ndatrunk Broken & Non-working equipment 11 08-09-2010 04:05 PM
[Resolved]Bad Coil? dropped_tb General Car Audio Discussion & Questions 52 10-20-2009 02:31 AM
