Design request for Whattha [Completed] - Car Audio Classifieds!
Old 08-27-2011, 04:54 AM
Ballz out!
0/11 ssssss203
Default Design request for Whattha [Completed]
Subwoofer/speaker brand:2x SA-8
Subwoofer/speaker model, size, and number of woofers:2x SA-8
Expected power handling: I have a DD M1B so more than plenty
Vehicle enclosure will be used in (please add notes if specific or unusual placement will be used):94 Ford Ext Cab truck
Max dimensions (MUST fit in vehicle or through trunk opening!):
Amp or expected power handling:Its gonna sit on back seat so it dont matter
Listening expectations (description):Everything
Are you looking for a heavy low end, or one that blends with the rest of the output? Heavy low end
How important is sound quality compared to loudness? LOUD
Are you able to cut odd angles? (45*, 7*..)If you design it I can build it
Old 08-27-2011, 01:55 PM
surreal's Avatar
0/11 sssss2489
Its going to sit on your back seat?
Any general dimension recommendations from you would be good to know just in case.
And just to make sure, low end is more important than upper end, correct? So I know how to orient the enclosure.
Old 08-27-2011, 02:10 PM
Ballz out!
0/11 ssssss203
Yeah that way I can take it in and out of my truck. Hell it can be 22 deep 20 height and 52 wide and yes lower end
Old 08-27-2011, 09:20 PM
surreal's Avatar
0/11 sssss2489
Wow! Sounds good. Ill see what I can come up with - design should be completed later tonight.
Old 08-28-2011, 12:33 AM
surreal's Avatar
0/11 sssss2489
Design has been completed and can be found/purchased here: 2x8s 1CuFt/34hz Truck or trunk box - $15.00 : TheBoxHouse, Enclosure designs
This design should work quite well for all 8s in either the truck environment (for low end as sub-forward port up) or in a trunk (as sub-up port back) for a good overall response, so it was placed under the Generic category.
Enjoy!!
Box request for kingtidis [Completed] kingtidis General Car Audio Discussion & Questions 11 10-27-2011 08:33 PM
design request for t.hybrid [Completed] t.hybrid General Car Audio Discussion & Questions 4 08-27-2011 01:11 AM
Design request for 3rdshift [Completed] 3rdshiftdiscretion General Car Audio Discussion & Questions 3 08-26-2011 12:36 AM
design request [Completed] darkkon General Car Audio Discussion & Questions 7 08-25-2011 09:07 PM
Box design for 03tbls [Completed] 03tbls General Car Audio Discussion & Questions 13 08-24-2011 04:58 PM
