Static from Tweeters? WHY? - Car Audio Classifieds!
Old 08-27-2011, 08:57 PM
EARmeBump's Avatar
0/11 ssssss404
Default Static from Tweeters? WHY?
Hey guys, so I've installed 2 pair of hertz components in my car.
When I mute the volume or turn it all the way to 0, I hear a static noise coming from the tweeters in my rear doors. I don't hear it in the front at all.
The rear tweeters are wired with 16 gauge while the front are wired with 18 gauge.
Is the 16 gauge the reason for the static-like noise? Or are the tweeters blown? When I crank the volume the music sort of drowns the static out, but it's still there none-the-less.
Thank you for the help!
It was a water bed, 6x9s mounted to the head board and the deck running off a radio shack power supply to set the mood for the girls. Not that there we many but I did OK.
I was born in the dressing room at walmart. My mom was a door greeter, my father a cart cowboy. Times were tough, but I pushed on and became manager of electronics at the des moines Iowa walmart.
Old 08-27-2011, 09:14 PM
k3n12ock's Avatar
Average Asian
0/11 sssss5963
Feedback Score: 49 reviews
RCA or ground issues mostly.
Old 08-27-2011, 09:15 PM
Shakindablock's Avatar
0/11 ssssss466
Do you hear engine noise when the car is running?
Old 08-28-2011, 03:04 PM
EARmeBump's Avatar
0/11 ssssss404
Can you please be more specific? What type of engine noise? Of course I hear noise from the engine when it's on.
Old 08-28-2011, 03:08 PM
DonH's Avatar
0/11 sssss6645
Feedback Score: 30 reviews
do you hear an increasing whine as you rev the engine? coming from the components. and your tweeters will most likely be producing the sound due to having a crossover point in which the high frequency of the engine whine will only play through them.
SHABAM
Old 08-28-2011, 03:55 PM
0/11 ssssss466
This is what I'm talkn bout^^^^^
Old 08-28-2011, 05:17 PM
EARmeBump's Avatar
0/11 ssssss404
No, I do not hear an increasing while revving. It is a constant whine/static noise. Whether the volume is at zero, or maxed out and muted, I hear the same pitched noise. I've checked the rca's and ground. I don't know what the deal-eo is!
Old 08-28-2011, 05:19 PM
0/11 sssssss43
Classic ground loop...
Check all your ground connections for being secure, appropriate gauge wire, clean contacts, etc...
As a precaution, remove signal wires from near by current wires... Not sure of the validity of this, as your whole vehicle is a ground, but worth a shot.
Ground your headunit independently, grounding through the factory harness is notorious for creating noise.
Don't ground to any zink plated factory bolts.. ie seatbelt bolts.
Isolate components to see where. The potential problem is, are the offending tweets on their own amp..
Lot of trouble shooting you can do...
Goofy static/noise problem Ronmeister General Car Audio Discussion & Questions 3 07-07-2011 04:07 PM
hey static, DIE! nicyousuckk General Car Audio Discussion & Questions 17 07-01-2011 05:07 PM
Static LivinLoud Sound Quality Area 0 02-14-2011 09:39 PM
static noise comming out of my sub... then nothing snoopysnooper General Car Audio Discussion & Questions 16 01-18-2010 10:27 PM
