Passive crossover question - Car Audio Classifieds!
Old 08-28-2011, 01:41 AM
0/11 ssssss338
Default Passive crossover question
I just bought a set of xst2 supertweeters and I am planning on putting a cap between each xst2 and mid.
Should I choose the capacitance based on the crossover frequency and the impedence of just the tweeter or the impedance of the mid and tweeter together?
I was looking at these caps
Dayton Loudspeaker Metallized Caps at Parts Express
and doing a little googling about passive crossovers
Designing Passive Crossovers
I'm looking to get a 12db/octave slope at 4000hz
Old 08-28-2011, 01:43 AM
2/11 ssss31256
just the impedance of the tweeter. {the tweeter is all that is controlled by the capacitor}
walled01alero (08-28-2011)
Old 08-28-2011, 01:45 AM
0/11 ssssss338
Ok thanks man. I was hoping I was just overthinking it.
Old 08-28-2011, 01:48 AM
DonH's Avatar
0/11 sssss6645
Feedback Score: 30 reviews
Sonic beat me too it. +1 if you are making your own crossovers. I will never go back to buying some!
SHABAM
Old 08-28-2011, 01:50 AM
0/11 ssssss338
Yeah I think it's about time for me to venture into the realm of making my own crossovers .
Btw what kind of slope will one of the caps from the link I posted produce?
Old 08-28-2011, 02:04 AM
2/11 ssss31256
A capacitor in series with the speaker makes a 6db per octave attenuation below the frequency.
1 octave = doubling or halving of a frequency
300hz is one octave above 150hz... 80hz is one octave below 160hz.
6db = 1st order = one crossover component
[highpass = capacitor in series]
[lowpass = coil in series]
12db = 2nd order = two crossover components
[2nd order highpass = capacitor in series & coil in parallel]
[2nd order lowpass = coil in series & capacitor in parallel]
Old 08-28-2011, 02:29 AM
Novicaine's Avatar
CACO Late Night Crew
0/11 sssss6135
Crossovers are very tough to actually design....If you havent studdied them well.
Okay, first:
The crossover point depends on the filter ORDER/type and along with that of the OTHER drivers.
Say you go with a ODD order butterworth filter for your tweeter's highpass, then you also go with the SAME for the midrange. For them to blend proper(flat) You must allow the F3 point of each driver to be the same because they will sum UP 3db at that point. If you choose an even order then they have to cross eachother at F6(6db down).
What's more is that even the acoustical phase of each blended driver will change the crossover! What i mean is the placement and angle of each component will change the crossover.
Also if you use inductors they will carry resistance...Maybe not a whole lot but be carefull. If it is significant then you will change the ts paramaters of the driver like the Qes which is something that is much more sensitive for high frequency speakers.
Its seems easy and you may want to try but you should study design first.
The Following User Says Thank You to Novicaine For This Useful Post:
Old 08-28-2011, 02:42 AM
0/11 ssssss338
Good info man.
Audiopipe CRX-303 3 Way Passive Crossover k3n12ock Wiring, Electrical & Other Installation Equipment 1 07-31-2011 10:13 PM
Should I get a passive crossover for my supertweets? crownvic97 General Car Audio Discussion & Questions 1 03-22-2011 06:06 AM
Passive crossover help for midrange speakers 46panel General Car Audio Discussion & Questions 1 02-06-2011 09:25 PM
wtb 3-way passive crossover blakflash Wanting to Buy (WTB) 0 07-27-2010 08:52 AM
Crossover Lesson (is your passive crossover labeled correctly?) iamsonic Tutorials & Quick References 0 01-20-2009 07:05 PM
