ordered subs today - Car Audio Classifieds!
Old 08-28-2011, 04:41 PM
98Expo's Avatar
0/11 sssss1929
Feedback Score: 23 reviews
Default ordered subs today
I finally ordered my subs today, now gotta get everything else together and get box design done. 4 audioque hdc318's d1's, gonna run 2 aq 2200ds strapped for now unless we keep working overtime then will get 2 aq 3500ds. WOOHOO
2 FI bl 18's walled in 2012 scion xb
Old 08-28-2011, 05:07 PM
0/11 sssssss17
Get the two aq 3500d.1s, if u cant get it right away, wait, save up, u'll wish you did! Just my .02 man
Old 08-28-2011, 05:14 PM
tommytee's Avatar
0/11 ssssss515
cool i just ran my 4 hdc3-a 18's strapped on two aq 3500's on te term lab.one alt is stock but it only runs the truck the other alt is 220 amp it is on only one yellow top,still not finished the install but wanted to burp a number with the comp port in the wall,did better than i thought 155.8 at 52 hrtz sealed on the dash at a very low 11 to 10.8 volts before amps shut down.going to get louder when i do the other alt and batteries. are you building a wall or box?
Old 08-28-2011, 06:24 PM
98Expo's Avatar
0/11 sssss1929
going with a wall behind front seats. Probably off 2 2200ds to start with. Will be awhile before can upgrade to 3500d's
Old 08-28-2011, 06:26 PM
98Expo's Avatar
0/11 sssss1929
I am running stock alt, group 65 xs power up front, will have 4 xs 3100s in back, 2 or 3 runs of 0 gauge to the back. Will have upgraded alt also soon after
Old 08-28-2011, 07:02 PM
tommytee's Avatar
0/11 ssssss515
i am going with 4 xs power 14 volt batts.my wall is in the third row area of my suburban.i took alot of pics for this build but not ready to show it off till its done,about another two weeks of work and i will be done,if i dont get too busy in my shop.look for the build log soon and if you need some help just ask.good luck on the build.
Old 08-28-2011, 10:35 PM
98Expo's Avatar
0/11 sssss1929
thanks tommy, i was going with wall behind back seat at first, but hell, i never use back seats. This is my work/play truck so figured I would just go this route the first time. I am going to start framing it all up next weekend and go from there. Still unsure if it will be a clamshell wall or flat. Im sure i may have some questions for you later
Old 08-28-2011, 11:13 PM
AMI CUSTOMS's Avatar
SOUNDQUBED EXPERT
0/11 ssssss524
I would do flat wall and you have enough battery to run 2 3500d.1, I ran two of them on just two d3100s and one d3400 and one 220 amp alt. Had some drop but wasn't bad.
3x STREETBEAT World Record Holder
-Streetbeat 4 - 161.9 db
-Streetbeat 5 - 162.6 db
The Black Nasty (SOUNDQUBED)- 160+ db
Old 08-29-2011, 12:42 AM
98Expo's Avatar
0/11 sssss1929
thanks ^^^ ami, as long as the money is right in couple weeks i am going with 2 3500's. We are supposed to be closing on our house next month so I was waiting til then to buy anything. But, my wife suprised me and bought me the subs today. So, depends on how things go next month and if my overtime keeps up at work for the amps. thanks for all the suggestions guys.
Old 08-29-2011, 01:37 PM
98Expo's Avatar
0/11 sssss1929
got my tracking numbers today from AQ, now hopefully I can order my 3500s in couple weeks
New subs in today! JMoney18 General Car Audio Discussion & Questions 23 07-21-2011 01:15 PM
Got 7 new subs today! Raptor660 General Car Audio Discussion & Questions 28 07-09-2011 11:41 AM
Couple of subs I started on today. [56k beware] 807tubenut Miscellaneous Build Logs 46 05-24-2011 01:33 AM
new subs ordered gettingloud15`s General Car Audio Discussion & Questions 8 02-27-2011 09:12 PM
So I broke 3 subs today tommyk90 General Car Audio Discussion & Questions 21 08-20-2010 12:02 PM
