Powering LED's and fans and more - Car Audio Classifieds!
Old 08-28-2011, 07:52 PM
LowLyfe's Avatar
0/11 ssssss200
Question Powering LED's and fans and more
Im getting ready to install my system into my car so im trying to put together a list of the equipment im going to need in order to hook everything up.
What im not sure about is where i should supply the power to the LED's and the fans for the amp rack from?
Also ive got a run of 1/0 going from the battery to the rear of the car which i will put a distribution block on the end to supply the power to both of my amps (a 1800.1RMS and a 500.4RMS) and a pair of compressors for the air ride. My question here is do i need to use a fused block or should i go with a standard block, and if it needs to be fused which size do i need for the amps?
Old 08-28-2011, 09:11 PM
The rule is: If you reduce the wire size at any point, you need to re-fuse for the wire size. I would assume that you are running 0/1 straight to the larger amp, so the wire should already be fused "upstream" to protect that. The 500 watter can be fused at around 80 amps. Six or 4 gauge should be fine for that one.
To turn on all of the accessories, use the remote lead from the headunit to turn on a relay. Supply the relay with power from the battery (fused at 5-10 amps) with 12 gauge wire. There's a tone of wiring diagrams on relays if you google it.
LowLyfe (08-29-2011)
Old 08-29-2011, 12:18 AM
LowLyfe's Avatar
0/11 ssssss200
Thats the info i was looking for. thanks bro, i have diagrams for relays so im good to go.
Old 08-29-2011, 12:22 AM
thumper21's Avatar
Blow-thru KING
0/11 sssss1919
why not do a simple toggle switch or switch panel for each accessory?
Speed and SQ
Old 08-29-2011, 12:24 AM
Wheres The Butta's Avatar
0/11 sssss6101
Feedback Score: 21 reviews
I use one like this, and I have the main power run fused as well.
I use toggle switches in line to the devices.
Blue Sea 5030 St Blade Fuse Block w/out Cover
____________________________________
IASCA Pro AM and MECA Modex -->
Old 08-29-2011, 10:17 AM
0/11 sssssss68
Switches will allow for easy repair and replacement too without worrying about accidentally grounding or shorting something along the way
Old 08-31-2011, 12:20 AM
LowLyfe's Avatar
0/11 ssssss200
Ive read alot on choosing a fused distro block to power multiple amps and i keep coming up with mixed answers on the correct way fuse the 4 gauge runs after the block. ive seen alot of "fuse for the wire size" and then "fuse according to the amp's fuse rating".... Not sure which way to go here.
According to a table i saw, 4gauge is good for up to 125amps max but one of the amps ive got is rated for 200amps and the other is rated at 150 amps
So which size fuses do i actually need? Somebody help a brotha out!!
Old 08-31-2011, 07:04 AM
0/11 ssssss413
If you fuse for your amp you'll be golden. I wouldn't run 200 amps out of a run of 4 gauge, but that's just me.
Old 08-31-2011, 11:19 AM
0/11 sssss6101
fuse for whatever is LOWER.
it doesn't matter if the amplifier can handle 200 if the wire is melting...
Old 08-31-2011, 11:04 PM
LowLyfe's Avatar
0/11 ssssss200
So i can run 150amp fuses at the distro block then 4 gauge to the amps and ill be good to go right? I just want to save myself from making the mistake of ordering the wrong stuff only to find out i gotta get something bigger.
VLEDS led's gbo559 Off Topic Chat 31 08-26-2011 03:42 PM
Replacing lights with LED's 92K1500 General Automotive Chat 8 06-08-2011 06:06 AM
Custom Tail-lights. Got LED's? NorthBeat General Car Audio Discussion & Questions 7 12-17-2010 07:36 AM
Oznium LED's Ryan1126 Off Topic Chat 10 01-20-2010 12:31 AM
Oznium LED's gbo559 Off Topic Chat 42 11-24-2009 11:30 PM
