what would u do? - Car Audio Classifieds!
Old 08-28-2011, 07:00 PM
massivespl's Avatar
0/11 sssss8409
Default what would u do?
i wanna get louded as does everyone.lol
right now i have a DD z2lv on 2 solo x 18's
should i sell the solo x's and get 2 different 18's?
or should i just get 2 more solo x 18's and have 4 total on he D z2lv
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 08-28-2011, 07:07 PM
0/11 ssssss332
That should be pretty loud, how does your voltage hold up?
Old 08-28-2011, 07:12 PM
massivespl's Avatar
0/11 sssss8409
holds up good, steady at 14 while driving and hardly drops at idle
dc alt and stinger batts ftw !!
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 08-28-2011, 07:14 PM
0/11 ssssss332
I got a 200 amp and I have been thinking about running 5K off of it. I drop in the 12s off 2800 at .5. I only have room for 3 group 51 batts so they dont help much. It should be better at 1ohm
Old 08-28-2011, 07:59 PM
tenbux1970's Avatar
0/11 sssss1247
From your sig I would say to add batteries.What do you do on the meter now? Daily set up,or meter set up?
Team DOA
FTMFW
Old 08-28-2011, 08:08 PM
Super Moderators
0/11 sssss9623
what size box are you using now with those monsters? whats it tuned to? ive heard of wayyyyy to many different sized boxes used with solo x's
Old 08-28-2011, 08:11 PM
bumpin buick's Avatar
Loud Noises
0/11 sssss9731
Feedback Score: 31 reviews
find the right box and tuning and everything else will work out just fine. No need to have more power or cone area at that point do get "loud" assuming your definition of loud is around the 150 mark, as is the majority of the users I would say.
Old 08-28-2011, 08:14 PM
massivespl's Avatar
0/11 sssss8409
went to use the meter today and the shop waS CLOSED and this is just a daily...
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 08-28-2011, 08:19 PM
massivespl's Avatar
0/11 sssss8409
the box i have now is 5.5^3 per woofer and tuned to 35hz like kicked said to. im pretty sure im at the 150mark but i wanna be mid 150's so u think changing my box wll help that much? insted of adding woofers or going with some woofers that can get louded or littler power?
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 08-28-2011, 08:22 PM
0/11 ssssss332
Tune higher and you should get the low 150s maybe more. Do right at 5cu a woofer?
