box design for keifersracing [Worked] - Car Audio Classifieds!
Old 08-29-2011, 09:31 AM
keifersracing's Avatar
Team Roto Rooter
0/11 sssss1407
Default box design for keifersracing [Worked]
Design request for [keifersracing]
Subwoofer/speaker brand:crossfire
Subwoofer/speaker model xs not the new ones, size12, and number of woofers: up to 4
Expected power handling:4k or more
Vehicle enclosure will be used in (please add notes if specific or unusual placement will be used): in the trunk and a blow through. Box can be built in car and can be bigger
Max dimensions (MUST fit in vehicle or through trunk opening!):34wX15tX24deap at the top and 29deap at bottom.
Listening expectations (description):I listen to every thing
What bandwidth is acceptable? 35-60hz high output, 30-80hz? Ignore if you do not understand: 32 to 51
How low do you want it to play and how important are the low notes (Song examples are encouraged)? i love the lows
Are you looking for a heavy low end, or one that blends with the rest of the output? it can blend
How important is sound quality compared to loudness? i want good sq
Are you able to cut odd angles? (45*, 7*..) yes
Is this an SPL design? If so, what is your peak frequency? If you do not know this, please measure your average cabin length in inches! NO
Any specific enclosure preferences (Double baffled, flush mount, center slot, blowthrough, home environment etc)? Blow through and yes doulbe baffled
NOTE: the opening ot top32 and bottom is 22 here is a pic
Old 08-29-2011, 09:37 AM
surreal's Avatar
0/11 sssss2489
First issue I see is fitting 4 12" subs on the face of the enclosure. I assume by blow through, you mean subs and port forward - not subs internal in a bandpass and port into cabin. Correct?
Ill look and see if I can find the specs for those woofers as Im not personally too familiar with them. If you happen to have specs for them please post them.
Old 08-29-2011, 09:48 AM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
Also I would extend the BW...30-50hz is very limited especially if you listen to more then just rap.
Just my .02
Old 08-29-2011, 10:03 AM
Team Roto Rooter
0/11 sssss1407
I do but not at high volume
Old 08-29-2011, 10:06 AM
Team Roto Rooter
0/11 sssss1407
I was just saying I have 4 to use. And ya I guess it would be sub mounted in side box and ported in to cabin. I will call roger and see about the spec
Old 08-29-2011, 10:12 AM
surreal's Avatar
0/11 sssss2489
Appreciate it, keep me updated.
And I can see three going well.
Ill wait til we get some specs to speak further.
Old 08-29-2011, 03:41 PM
Team Roto Rooter
0/11 sssss1407
Ok I talk to roger and my 12 are custom built so there are no spec
Old 08-29-2011, 03:48 PM
Novicaine's Avatar
CACO Late Night Crew
0/11 sssss6135
Buy a tester if he can.
Old 08-29-2011, 03:56 PM
Team Roto Rooter
0/11 sssss1407
Just. Don't want to lol but may have to
Old 08-29-2011, 07:11 PM
surreal's Avatar
0/11 sssss2489
Hm, either way it will be tough unless you go sub up in a ported enclosure, or take a risk building a more complicated enclosure since you dont have much of a starting point.
If you are patient and good with computers, you can build a test jig like I did for a few bucks. I have a thread on it in the tutorial section.
Otherwise we can fit at least two subs facing in-cabin. A BP would be a possibility with three of them stagered but may be a close call, and again would be something of a risk build but has potential for good results.
Box design request for keifersracing keifersracing Box Requests 0 08-28-2011 07:10 AM
Box design request for keifersracing keifersracing Box Requests 0 09-06-2010 11:27 PM
What I got to worked on yesterday... SundownAudioNY General Automotive Chat 9 07-18-2009 09:17 PM
