Serious interference - Car Audio Classifieds!
Old 08-29-2011, 12:56 PM
18psi's Avatar
0/11 ssssss500
Default Serious interference
So my buddy's truck has a nasty whine interference.
When we did the original install everything was fine. We removed sub amp and subs. Now the 4 channel has a ridiculous whine.
I replaced the ground, remote, and Rca's. I reran the rcas on the opposite side of power and remote. Have tried inline sound isolators and nothing works?
Any suggestions ?
Old 08-29-2011, 01:03 PM
0/11 ssssss413
Ground loops and eliminating them (informational)
Old 08-29-2011, 01:09 PM
tacomaguy1's Avatar
0/11 sssss4401
what headunit does he have
Team Flex Issues
96 Blazer
4 18" Mayhems
2 TFE 8k's
Old 08-29-2011, 02:13 PM
18psi's Avatar
0/11 ssssss500
It's a newer kenwood. I'll get the model number
Old 08-29-2011, 02:23 PM
18psi's Avatar
0/11 ssssss500
Kenwood Kdc-bt945u
Old 08-29-2011, 02:29 PM
If you pull the RCAs from the amp (therefor feeding no signal), is there still a whine?
Old 08-29-2011, 04:01 PM
18psi's Avatar
0/11 ssssss500
No...
And I read the link, tried all of that. Just gonna run all new wire, as I have replaced everything except the power...
Old 08-29-2011, 04:26 PM
If there's no whine when you unplug the signal input (RCAs) to the amp then the issue isn't with the amp. Try re-grounding the headunit in a different spot.
Signal Interference 6.5ldiesel General Car Audio Discussion & Questions 1 01-29-2011 09:40 PM
