Sub wiring with a twist - Car Audio Classifieds!
Old 08-29-2011, 06:58 PM
0/11 ssssssss9
Default Sub wiring with a twist
Is there any difference between connecting a D2 in parallel using the same side's vc + and - to run to the amp vs. running 1 side's vc + and the other side's vc - to the amp? Before the question is asked, both + will be connected together and both - will be together. Thanks.
Old 08-29-2011, 07:07 PM
Dbmonster's Avatar
0/11 sssss1217
I had to read that a few times to understand what you are asking, but I think I get it.
no there will be no difference
WARNING: Due to high sound pressure levels, all passengers are encouraged to remove any and all tight or restrictive clothing such as bras, thongs, etc. before entering this vehicle.
Old 08-29-2011, 07:15 PM
0/11 ssssssss9
Thanks for the reply.
So to clarify: VC1 + to amp + and VC1 - to amp -. VC1 + connected to VC2 + and VC1 - connected to VC2 -.
VC 1 + - VC2 + -
amp + -
Old 08-29-2011, 08:15 PM
Seconded. As long as all "-"s and "+"s are connected somehow you'll be fine.
Old 08-29-2011, 08:37 PM
0/11 ssssssss9
Thanks guys. that's what i thought but wanted confirmation before i fsu.
help wiring! 423bass General Car Audio Discussion & Questions 2 07-14-2011 07:43 PM
Another VMInnovations coupon giveaway with a twist & sweeps update LuckyatVMI General Car Audio Discussion & Questions 3 05-08-2011 05:39 PM
Craziest frame twist i have ever seen Violence* General Automotive Chat 30 03-04-2010 11:44 AM
H/U wiring gjnelson General Car Audio Discussion & Questions 0 11-21-2009 01:27 PM
Sub Wiring ??? Blackout General Car Audio Discussion & Questions 18 01-30-2009 06:59 PM
