2 Custom UFO 18's or 6 Type-R 12's - Car Audio Classifieds!
Old 08-30-2011, 12:03 AM
lilteddyp's Avatar
0/11 ssssss403
Default 2 Custom UFO 18's or 6 Type-R 12's
Tried this over at SMD and didn't get very many hits.....
Ok, so me and 97ssblazer are in a debate, or kind of a this or that, on what would be louder, sound better, and be better over all.
Back story, I have 2 UFO BTL motors that I want PSI to build into 3000+ RMS to run each on a T2500-1bd (Not CP). 97ssblazer (Mike) is saying instead of having those built, sell the motors and do 6 Type R 12s.
Cost aside (cause the type rs are stupid cheap and that would win for cost), what would be better?
He says 6 12's cause it will have more cone area 480cm^2*6=2880cm^2. I can't argue that, it has more cone area. But from what I have been reading, it's cone area * xmax. If this is the case then it will be
480*20 = 9600*6 = 57600 for the 6 12s
If the 18's are built for a 28mm xmax as fi's have
1210*28 = 33880*2 = 67760 for the 2 18s
I know there needs to be a lot more in to this like box and power and what not to make a REAL informed decision, but what do you guys think?
I think the 2 18s with be better, he says 6 12's. The good thing about the 12's is they are a stocked piece so if I blow them (speading 2500RMS+ between each set of 3) I just swap them out, and they are stupid cheap.
It will be in a 97 GMC Jimmy in the cargo area, sub up port up. If more info is needed, LMK, I will try and keep this up from my phone.
Let's throw this in the bottom, who has had experience with the new T2D215s? Should I just keep them and run them at 1 ohm each?
2001 Bravada (2wd) Pewter|JVC KW-AV60BT|Alpine Interiors|2 PSI/BTL 18's @ 32Hz|2 Rockford Fosgate T25001-bd's @ 4-ohm each|Rockford Fosgate T1000-4 on Mids|Rockford Fosgate T400-4|RF 3Sixty.2|Yellow Top up front 2 9a31s in back|LOTS of AT 1/0|Python 991|350a Singer Alt
Old 08-30-2011, 12:10 AM
0/11 ssssss270
Id say build the btls. Sub up port back. David is a badass sub builder so let him do the recone
Old 08-30-2011, 12:20 AM
lilteddyp's Avatar
0/11 ssssss403
Would be Subs up Port up, only way to do it in those trucks with a box that big due to limited space and how the amp rack would have to go in there.
Old 08-30-2011, 12:37 AM
RE_XXX's Avatar
0/11 sssss3181
Type Arrggghhsss!!!!!!
Amps- Crossfire XS-8X
Wire- 6 runs Stinger
Old 08-30-2011, 12:39 AM
thumper21's Avatar
Blow-thru KING
0/11 sssss1919
type R's
I wouldnt have psi touch anything of mine
Speed and SQ
Old 08-30-2011, 12:58 AM
Kidthump's Avatar
Awaiting Confirmation
0/11 ssssss346
R's for sure. 6 12's would be ridiculous.
01 Jeep Grand Cherokee Laredo 4x4
JVC KD-S26-1/0 Gauge-Audiopipe 1002
2 Obsidian 15's-Audiopipe 1500d
7 Cubes, 30hz
Old 08-30-2011, 01:08 AM
0/11 ssssss579
. I personally would go with 6 12s for a daily setup.
who switched from 18's to 12's? murderedtahoe General Car Audio Discussion & Questions 24 11-02-2011 04:34 PM
15" custom BTL ufo style iLLsT0LZ 15" Subwoofers 15 08-11-2011 01:52 PM
4 alpine type x 12's in custom ported box. allentown pa, will meet up. kickerfanatic Car Audio Packages 8 04-28-2011 11:08 AM
2-18's or 4-15 or 4-12's tjjohnson91 Wanting to Buy (WTB) 22 04-07-2011 09:30 AM
4-12's or 2-18's? Violence* General Car Audio Discussion & Questions 6 11-10-2009 07:54 PM
