2 ohm vs 4 ohm - Car Audio Classifieds!
Old 08-30-2011, 08:09 PM
nicholask1993's Avatar
Dubstep Addict
0/11 sssss1802
Default 2 ohm vs 4 ohm
I'm getting a Skar VVX 15" sometime next month and don't know if I should get the D2 or D4 model. Right now I have a Dual 470w amp that I would use temporarily until I find a better amp to give it ~600w.
I have all stock electrical in my 99 Corolla and don't plan on doing anything but the big 3 electrical wise per budget and the fact that I'm hopefully getting a new car this year.
I've heard that the higher the ohm load the more efficient... Would it be worth the extra money for an amp that would give me 600w at 4ohm or would the difference between that and 2ohm be not worth worrying about?
1998 Subaru Forester
Sony CDX GT-565UP Head Unit
Cadence 6.5" Components
MB Quart Onyx 1500.1
/Surreal
Old 08-30-2011, 08:12 PM
0/11 ssssss332
You need to know what amp choices you have for your budget then narrow it down to a final ohm load. I can tell you 1ohm amps are normally cheaper then 2ohm amps
Old 08-30-2011, 08:16 PM
sthrnbumpn's Avatar
0/11 sssss2961
Feedback Score: 21 reviews
good question, [email protected] is my choice, i got a [email protected] bridged an its a quite a bit bigger than the 601 equivalent of it, vr series amps,
another good thing about [email protected] is that you can always go up in power, if you need it, plenty of overhead
get a 2nd d2 sub later an you can double your power if you have the rite amp
Old 08-30-2011, 08:17 PM
0/11 sssss1868
Like haze said... depends on your amp choice. You could always look for an amp that does around 1200-1500 @ 1 ohm... that should get you your 600 if you wire it at 2 ohms with a dual 4 sub. It also saves you money if you choose to add another sub in the future, as you can simply get another dual 4 sub and wire it down to 1 ohm without having to get a bigger amplifier. The AQ1200D comes to mind....
Old 08-30-2011, 08:20 PM
Dubstep Addict
0/11 sssss1802
I guess my budget would be $250 for the amp.
My plan was to run it at 1ohm but I was told on another forum that for daily use a higher ohm load more efficient.
As for getting a second sub that won't happen until I get another vehicle. I can't take up my entire trunk as my Dad uses my car from time to time and needs some trunk space...
/Surreal
Old 08-31-2011, 08:15 AM
0/11 ssssss413
AP1500d, go dual 4. Amp meets your budget.
Old 08-31-2011, 08:24 AM
mtrevino92's Avatar
0/11 sssss1526
I'd say go for a Kicker zx750.1. It does it's power @ a 2 ohm load and can be had well within your price range.
Old 08-31-2011, 12:04 PM
Dubstep Addict
0/11 sssss1802
I'm going to go Dual 4. Most of the amps that have efficiency ratings only worsen by 2-3% going from 4 to 2 ohms and then drop by around 10% going to 1 ohm.
Plus I'll be able to use my current Dual mono amp and get 470w out of it until I buy a better quality amp.
/Surreal
Old 08-31-2011, 12:06 PM
grimreper912003's Avatar
Hook me up with dat JL
0/11 sssss6190
Dont use efficiency to tell you everything.
If you go D2 with a single sub set up you have the option of running a 2ch bridged at four ohm or a mono block at one ohm.
Old 08-31-2011, 12:27 PM
0/11 ssssss165
remember that 1 ohm generally has the worst sq and efficiency and 4 ohm is generally a class a/b 2 channel so not as efficient as a class d. Also since all amps are different not every amp will fall under these rules but most will
2500-3000 @ 2 ohm or .5 ohm joey2010 Wanting to Buy (WTB) 4 07-26-2011 05:21 PM
can i put a 1 ohm sub on a 2 ohm amp JLAUDIO Bo1 901 General Car Audio Discussion & Questions 5 06-19-2011 10:50 AM
[TRADED]mmats modded dhc1400.1 2000 rms @ 1 ohm & 0.5 ohm stable kickerfanatic Mono Amplifiers 10 02-07-2011 08:27 AM
WTB 2k watt amp at 1 ohm or 4 ohm ltent Wanting to Buy (WTB) 2 10-18-2010 07:21 PM
6 ohm woofer + 4 ohm component set? gbo559 General Car Audio Discussion & Questions 14 07-14-2010 03:06 PM
