4th order design for 4 Type-Rs - Car Audio Classifieds!
Old 08-30-2011, 11:25 PM
surreal's Avatar
0/11 sssss2489
Default 4th order design for 4 Type-Rs
This was a design by request from someone who I dont believe is a member here but I figured it was cool so Id share anyway.
Was requested for a mix of rap/low end and rock. Is a blowthrough design for a truck.
Hoping I receive build pictures for this project.
Design is about 5 sealed and 10 ported. Yes, it is a 1:2 design. This is mostly coincidence and they arent always this way!
If you feel youre looking to do a similar setup and your subs are a good candidate for this design, it can be found/purchased here:
4xType-Rs 4th order bandpass blowthrough - $20.00 : TheBoxHouse, Enclosure designs
If you arent sure, shoot me a message and like any design Ill take a look and see how well suited the enclosure would be for your build.
Old 08-31-2011, 01:56 AM
mads10bass's Avatar
NOT LOUDER THAN YOU :(
0/11 sssss7335
Feedback Score: 36 reviews
im deff on here my friend
WOW
Old 08-31-2011, 01:58 AM
surreal's Avatar
0/11 sssss2489
Was that you? Haha!
I didnt know. Nice to make the connection. Hope you get a build log going.
Old 08-31-2011, 02:08 AM
mads10bass's Avatar
0/11 sssss7335
going to try here soon. guy stopped by today and picked amp up was waiting on this i gotta go thru and make a supplies list now.
WOW
Old 08-31-2011, 05:37 PM
surreal's Avatar
0/11 sssss2489
Gotcha. If anything isnt clear just holler.
I would recommend rounding over the inner port entrance if at all possible. but if not it shouldnt cause any issue.
*waits*
Old 08-31-2011, 06:01 PM
oxsign's Avatar
0/11 sssss1876
Very nice. I'm looking to so the same with 2 15" in my truck.
Old 08-31-2011, 07:29 PM
mads10bass's Avatar
0/11 sssss7335
yup getting wood tomorrow and i have 3/8 roundover for my router so that can happen
WOW
Old 08-31-2011, 07:59 PM
got160s?'s Avatar
0/11 ssss13630
So why not a v just asking?
Vehicle: 1999 Chevy Suburban AKA The Bammin' Beast
Battery: 25 XS Power XP1000's
Sub Amp: 3 DC 9k's
Sub Stage: 18 DC Lvl 4 M2 12's in a Nasty 4th Order
Subscribe now! Prizes will be given away for every 1000 subscribers!
Old 08-31-2011, 08:11 PM
surreal's Avatar
0/11 sssss2489
Oxsign: Sounds good. Let me know when youre ready!
160s: It depends, but normally firing directly into a port isnt the favored option. Side-firing and having the port off axis from the subs gives them a wall to 'load' on.
Other reasons:
It allows the subs to be mounted from the sealed section into the ported section, which will add support to the woofers to the basket as normal from the baffle. As opposed to being inverted and mounting purely from the face which can be stressful on the woofers IMO. Not to mention it essentially adds a very small 'port' or chamber between the cone and the compression chamber. Which may be negligible but its best to avoid. Effects of this can be modeled in hornresp for reference.
Having the woofers in the ported chamber may help with cooling too.
Originally, I wanted to do two on each side but due to a relatively short height of 15 inches the sealed chambers would have been very skinny. Which that in its self isnt particularly a good thing, along with not allowing the woofers to be mounted through the baffle which would remove the support I mentioned earlier.
Lastly.. I do believe it is an easier build this way. Sometimes some things look cool, but something more simple may perform better
Old 09-01-2011, 06:49 PM
That Guy
0/11 ssssss289
anyone have a good program to design boxes?
4th order design bassbear007 General Car Audio Discussion & Questions 1 02-17-2011 07:57 PM
4th order for 2 Type R 12's white4d96 Enclosure Discussion & Design Construction Help 4 09-17-2010 02:45 AM
4th order design spl-101 General Car Audio Discussion & Questions 13 08-22-2010 06:05 PM
12" Type R 4th order grimreper912003 Enclosure Discussion & Design Construction Help 11 03-10-2010 08:50 PM
4th order bandpass, two Type R 12's white4d96 Enclosure Discussion & Design Construction Help 0 11-07-2009 03:08 PM
