Design Request for rmaravetz [Completed] - Car Audio Classifieds!
Old 08-31-2011, 01:05 PM
rmaravetz's Avatar
0/11 sssss1013
Default Design Request for rmaravetz [Completed]
Subwoofer/speaker brand:
Subwoofer/speaker model, size, and number of woofers:
L5 15"
Expected power handling:
1000w
Vehicle enclosure will be used in (please add notes if specific or unusual placement will be used):
Cargo areaof 2003 Tahoe
Max dimensions (MUST fit in vehicle or through trunk opening!):
40"deep 49"wide and 18" tall
Listening expectations (description):
want it to sound good with all music
What bandwidth is acceptable? 35-60hz high output, 30-80hz? Ignore if you do not understand
How low do you want it to play and how important are the low notes (Song examples are encouraged)?
i want it to sound good with beats like "the whisper song" Ying Yang Twins
Are you looking for a heavy low end, or one that blends with the rest of the output?
Heavy Low end
How important is sound quality compared to loudness?
prefer quality
Are you able to cut odd angles? (45*, 7*..)
No
Is this an SPL design? If so, what is your peak frequency? If you do not know this, please measure your average cabin length in inches!
Any specific enclosure preferences (Double baffled, flush mount, center slot, blowthrough, home environment etc)?
single slot i like slot ported but whatever sounds best maybe make it so i mount 2 screens one on each side.
Old 08-31-2011, 04:41 PM
surreal's Avatar
0/11 sssss2489
Just to verify, you are unable to cut 45s correct? That may be a bit limiting.
I have a few designs ahead of yours, but should have it done within 2-3 days if that works for you.
Old 09-02-2011, 12:36 PM
rmaravetz's Avatar
0/11 sssss1013
i might be able to cut 45s
Old 09-02-2011, 03:52 PM
rmaravetz's Avatar
0/11 sssss1013
i forgot to tell you this is for a single sub
Old 09-03-2011, 10:44 PM
surreal's Avatar
0/11 sssss2489
I have a good idea for what Id like to do with this design, however it would require 45s and a single little angle cut (like 7 degrees for example).
Is this possible?
Old 09-03-2011, 10:49 PM
rmaravetz's Avatar
0/11 sssss1013
Yeah it is possible how long you think until it is done just curious
Old 09-04-2011, 01:21 PM
surreal's Avatar
0/11 sssss2489
Most likely today.
Old 09-04-2011, 07:56 PM
rmaravetz's Avatar
0/11 sssss1013
cool just let me know when its done thanks bud
Old 09-04-2011, 09:56 PM
surreal's Avatar
0/11 sssss2489
Design has been completed and can be found/purchased here: Kicker L5 15 T-line enclosure - $25.00 : TheBoxHouse, Enclosure designs
Enclosure will be a wonderful mix of output, extension, and sound quality.
Recommended to start testing placement furthest from hatch.
Also suggested to be built from birch, and to use a subsonic setting of 25hz on 1000w
Old 09-04-2011, 10:05 PM
rmaravetz's Avatar
0/11 sssss1013
Why is this $25 it says vented are only $15 just curious. It looks really nice I like it thank you
Design request for e2 [Completed] e2theloc General Car Audio Discussion & Questions 14 09-02-2011 08:13 PM
Design Request [Completed] 060gon General Car Audio Discussion & Questions 2 08-31-2011 11:08 PM
Design request for Whattha [Completed] Whattha General Car Audio Discussion & Questions 4 08-28-2011 12:33 AM
design request for t.hybrid [Completed] t.hybrid General Car Audio Discussion & Questions 4 08-27-2011 01:11 AM
design request [Completed] darkkon General Car Audio Discussion & Questions 7 08-25-2011 09:07 PM
