low voltage WTF!!! - Car Audio Classifieds!
Old 08-31-2011, 06:16 PM
Amp blower!
0/11 ssssss483
Default low voltage WTF!!!
was i just upgraded the alternator and had it rebuilt. but the problem is when i drive the car in town, and give it gas the voltage drops to 12.5, but when i let off the gas it charges up in the 13.8 14.4 range. and i jus charge the batts and they are setting at 12.8 right now. so what is the problem? batts? idk
thanks in advance!!!
Old 08-31-2011, 06:33 PM
Amp blower!
0/11 ssssss483
oh yea and that is with the system off and the ac, ect
Old 08-31-2011, 06:35 PM
0/11 ssssss776
Sounds like the belt is slipping. Mine did that on my jeep. I tightened the belt of and its fine now.
1993 Jeep Cherokee 4 Sundown ZV3 15s, 2 Sundown NS-1s, 4th order BP, 12 XS Power d1600s
3 Mechman 300 amp alts
2011 NC Middleweight champion
2011 Middleweight World Champion
2012 Middleweight World Champion
157+ 3 round music avg
Old 08-31-2011, 06:44 PM
Amp blower!
0/11 ssssss483
^^^well did you change your belt or just tighten it?
Old 08-31-2011, 06:45 PM
Amp blower!
0/11 ssssss483
because i did when i changed the alt
Old 08-31-2011, 06:56 PM
TeamNemesisVance's Avatar
0/11 ssssss400
high output alts have a smaller pulley and its more prone to slip. it does sound as if its slipping because as it slips the alt stops charging because the alt pulley slows down. sometimes you have to use a slightly shorter belt to get enough tension.
2011 SPRING BREAK NATIONALS IdBL ADVANCED NO WALL 2 CHAMPION
153.4 on music at 45hz/SUB BOX and CENTER CONSOLE by SBC (SCOTT BOWMAN CUSTOMS)
Alpine iva-d100 dvd headunit
6 Sundown SA12s
2 Sundown 3500
rockford P450.4
rockford P325.1
Diamond hex components
2 Punch P1 8s for midbass
dual Powermaster 200 amp alternators on custom bracket made by me
9 batteries (7 datasafe hx300s in the rear and 2 Optima blue tops up front)
lots of 1/0 and some 4/0 welding cable
Old 08-31-2011, 07:14 PM
0/11 sssss1463
Feedback Score: 21 reviews
just out of curiosity what vehicle is this on? Most newer cars have a belt tensioner. If your vehicle doesnt have one id say loosen the alt a bit and adjust alt up or down which ever way tightens.
Contact me to get orders for any of your B2 Audio needs. I am an Authorized Dealer
REFS-DAPPA5, BRIAN OWENS, --Navi-- , X1le, Basscort2009, vitveet, thumpper, Lousiana_CRX, woofercooker, tez4life, 913 customs, davidrforbus, bluieorbluee, lil98cabrio, Dropped_TB, orangecounty1, dbeez, Seifert, JB Livewire, rmaravetz, 72impala
Old 08-31-2011, 08:41 PM
Amp blower!
0/11 ssssss483
it is a 98 Honda accord and i just put on a new belt and it is the same. this sucks.
Old 08-31-2011, 08:53 PM
Amp blower!
0/11 ssssss483
any more advice anyone?
Old 08-31-2011, 09:01 PM
Dunder Mifflin
0/11 sssss1897
Ground issue ? I had a similar problem just not as low of a voltagendrop
jordan i want my subs
low voltage basswagon General Car Audio Discussion & Questions 10 06-02-2011 09:09 PM
Low charging voltage jt_buck General Car Audio Discussion & Questions 9 05-28-2011 07:27 AM
How low should my voltage drop? Jdubs04ss General Car Audio Discussion & Questions 68 05-15-2011 12:12 PM
Voltage drops, wtf? Ryan1126 General Car Audio Discussion & Questions 21 07-04-2010 01:47 AM
Low voltage? splvictim20 General Car Audio Discussion & Questions 26 10-02-2009 11:56 PM
