Replacing headunit in 04 grand prix with monsoon stereo ?'s - Car Audio Classifieds!
Old 08-31-2011, 10:15 PM
0/11 ssssss155
Default Replacing headunit in 04 grand prix with monsoon stereo ?'s
hey guys i just purchased an 04 grand prix gtp with the monsoon system in it. i am looking to upgrade to a Kenwood Excelon KDC-X395 headunit and i have done research and found that i need a special wiring harness to keep my door chime and alerts and what not which i will be purchasing. the headunit has 4v pre outs and i was wondering if this would cause any problems with the stock monsoon system/amp? I am adding a bass amp along with 2 12's also and was wondering if i will have any problems with this? dumb question but i am finding out this factory upgrade is a big pain in the ass. thanks caco.
Old 08-31-2011, 10:27 PM
0/11 ssssss165
if your that worried about it doing an amp bypass in one of those is cake. all the speaker wires are ok with a normal harness but i dont remember how or if remote is up at the HU to turn on the stock amp
Old 08-31-2011, 11:05 PM
0/11 ssssss155
that had crossed my mind..i will do some research on it. thanks
Old 08-31-2011, 11:22 PM
0/11 ssssss165
it really isnt bad. amp is under the rear deck trunk side. i can help you if needed but its not quite a plug and play deal (someone might make a harness that is thou)
Old 09-01-2011, 12:03 AM
0/11 ssssss155
any help would be appreciated man...would that enable the factory speakers to be run by just the upgraded headunit? if there is a harness that would allow me to just easily bypass the amp that would be awesome!
Old 09-01-2011, 12:31 AM
0/11 ssssss165
check metra or x-scorpion for the harnesses
The Following User Says Thank You to emperorjj1 For This Useful Post:
AndrewBR98 (09-01-2011)
Old 09-01-2011, 12:46 AM
0/11 ssssss155
i also am looking into these RCA Line Level Attenuator 6 dB they lower the sensitivity and should drop the pre out voltage of 4v from the new head unit to about 2v (ive heard) on the monsoon amp which is the same as stock i believe...would be cheap and easy! any idea if that would work? and then i could directly hook up the external sub amp on the remaing outputs and get 4v pre outs to that separately.
Old 09-01-2011, 12:52 AM
0/11 ssssss165
maybe but running the 4v preouts vs the 2v that came stock wouldnt really make a big enough deal to require the attenuator. the main problem you get is if you use speaker level input, then your sub gain is way lower then ur now maxed highs level
Old 09-01-2011, 12:59 AM
0/11 ssssss155
would it be beneficial to just go with a headunit that has 2v pre outs? that would solve a lot of problems. what is better about a headunit with 4v preouts rather then 2v?
Old 09-01-2011, 01:09 AM
0/11 ssssss954
did it in my contour, just rerun speaker wires
current setup: empty dual 10's box tuned to 34 hz, dual touchscreen upfront, oldschool hifonics warrior eagle 4 channel pushing 2 infinity 5x7's up front and 2 pioneer 5x7's in the rear.
after the massage... IF you ship it next day. i also require a reach around for this deal to work
nicklbmx's DC Grand Prix nicklbmx (DC) 7 08-27-2010 10:50 AM
04 grand prix mythyone General Car Audio Discussion & Questions 0 07-10-2010 07:10 PM
2 10's in a Grand Prix casper129 Car Audio Videos 25 04-10-2010 09:38 PM
my new car -04 grand prix 99grandprixgt Member Rides & System Pictures 48 10-26-2009 08:22 PM
My 08 Grand Prix. itsbmw Member Rides & System Pictures 5 10-16-2009 05:12 AM
