False Floor Material - Car Audio Classifieds!
Old 08-31-2011, 10:18 PM
0/11 sssssss63
Default False Floor Material
Just wondering what you guys thought would be the best false floor material. I need to replace the stock carpet/flooring in the trunk and need to get started on it before I can put my box in. I still need to be able to access the spare tire that is in the trunk too since my car is a daily driver.
I would like to flush mount my amp into the floor, box, side panel if one is made. Any help is appreciated.
Bought from: thel.t.d.supply
Old 08-31-2011, 10:28 PM
0/11 ssss31255
I use a combination of materials. {plywood, straight regular wood}
I avoid MDF on floors though because MDF absorbs moisture. (more than other materials do)
Old 08-31-2011, 10:33 PM
0/11 sssssss63
And thats what I thought about using MDF too. Just trying to think of the easiest, cost friend method.
Old 08-31-2011, 10:34 PM
0/11 ssssss165
wood. ive seen them done with 3/4 mdf, 1/4 ply, hardboard you name it just depends on you application really
grocerygetter's Avatar
New build coming soon?
0/11 ssssss583
i used MDF for my false floor but its not replacing the stock floor lol
Old 08-31-2011, 10:37 PM
0/11 sssssss63
I think my best bet is to go with 1/4" ply and then cover it with carpet to match.
Old 08-31-2011, 10:39 PM
dumple's Avatar
0/11 ssssss535
i used half inch for my floor and 3/4 for the beauty board, covered with vinyl
2012 Hyundai Genesis coupe rspec 3.8
Pioneer appradio 3, JBL Ms8, CDT M6+, PHD Studio 6.1 neo
Fornow....
Old 08-31-2011, 10:43 PM
Matt3824's Avatar
0/11 sssss3754
Mine is 3/4 MDF, with 2x4s and 1x6s supporting it. Bolted to the cap FTMFW
Old 08-31-2011, 10:46 PM
0/11 sssssss63
1/2" MDF?
And explain to me what a beauty board is.
Old 08-31-2011, 10:56 PM
0/11 ssssss340
as a floor you can use 1/4" of any type of wood. birch ply would be the lighter than mdf and anything you place in there just make sure to place a coat of fiberglass resin on before carpeting and never have a problem with moisture swollen material.
custom false floor enclosure jeep/suv BlueDevil00 Wiring, Electrical & Other Installation Equipment 10 04-26-2011 08:43 PM
Best way to go about a false floor? maybe some even have pics? mattintc10 General Car Audio Discussion & Questions 16 03-01-2011 11:52 PM
GearGuy2001's 4th Order, False Floor, Sundown SA-10 Build GearGuy2001 Build Logs 42 01-07-2011 06:43 PM
False floor? premierdime General Car Audio Discussion & Questions 6 11-05-2010 05:42 PM
False Floor Amp Rack gbo559 General Car Audio Discussion & Questions 11 07-20-2009 02:00 AM
