spider separated from cone? - Car Audio Classifieds!
Old 09-01-2011, 12:55 PM
0/11 ssssss153
Default spider separated from cone?
so today i was looking at my audioque hdc3 12's and the cone has completely seperated from the spider. I used the subs not to long ago and they sound fine and play fine. Im just wondering what to do now? should i fix it with glue or what? what will happen if i just leave it and use it as is?
Old 09-01-2011, 12:58 PM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
First off...you need to correct the issue that caused the problem in the first place. Which more then likely was playing under tuning of the enclouser.
As far as repairs go...if the spider is still attached enough you could re-glue it and hope it was centered. Or cut off the dust cap carefully and shim the coil and do it that way.
Or play it till it dies and buy a new drop-in recone.
Old 09-01-2011, 01:05 PM
0/11 ssssss153
It is completely detached i can see white underneath which is the voice coil i think? what could i use to glue it back apoxy or what?
Old 09-01-2011, 01:16 PM
mcmuffin's Avatar
0/11 sssss3380
epoxy is a temporary fix to a severe problem, the triple joint failed, id say order a new drop in cone and tell them to re-inforce the triple joint then drop it in
*** NEW BUILD COMING SOON ***
its a secret for now
Old 09-01-2011, 01:33 PM
bumpin buick's Avatar
Loud Noises
0/11 sssss9731
Feedback Score: 31 reviews
What is the box tuned to... may want to check out your subsonic filter settings
Old 09-01-2011, 01:36 PM
ascitiesburn69's Avatar
0/11 sssss1645
Did you actually push on it to see that it wasn't attached? Because IIRC on older AQ recones they glued the spider pack further down the former than the cone. Which would cause some "white" to show.
I can't see how it would play fine without the spiders being attached to the cone....
Team S.P.E.A.D.
Trunks FTW
Old 09-01-2011, 04:13 PM
0/11 ssssss153
Box is tuned to 38hz but I dont currently have it set up im waiting on my nendo 3500 to get here. when I push on the sub it all moves as one like normal. Just looks like the gap with seeing the white shouldn't be there but I really cant even remember if it was always like that or not lol maybe it was built like that? I bought them brand new
Old 09-01-2011, 04:15 PM
tacomaguy1's Avatar
0/11 sssss4401
so you don't even know if it's seperated? They worked fine when you took it out, what happened since then and now?
Team Flex Issues
96 Blazer
4 18" Mayhems
2 TFE 8k's
Old 09-01-2011, 04:30 PM
0/11 ssssss153
They have worked fine the whole time nothing has happened I was just under the impression the spider should be directly connected to the cone without the little gap I seee with white in it. am I just tripping and it can be like that?
Old 09-01-2011, 04:33 PM
RE_XXX's Avatar
0/11 sssss3181
Pics......
as long as the spider/coil didnt shift and are sitting neutral you dont need to shim the coil. If the cone did seperate from the triple joint, all you have to do is reglue it. Take the dustcap off and reglue around the bottom of the cone and on the bottom of the cone above the spider.
Im not sure if Audioques recones come as one,two or three piece...as most of mine are 3 piece, so to me this isnt that big of a problem.
Amps- Crossfire XS-8X
Wire- 6 runs Stinger
I have a noisy spider on a new cone... Pillow General Car Audio Discussion & Questions 10 02-02-2011 08:32 AM
WTB:Spider and Cone spencerearl1996 Wanting to Buy (WTB) 15 01-05-2011 07:08 PM
Pinky! The 12" sub with a pink motor, terminals, spider, and cone! TeamPSI (Fix My Speaker) 32 04-15-2010 12:42 PM
sub repair - possible to just re glue spider to cone? nefariouscaine General Car Audio Discussion & Questions 13 04-12-2010 10:14 AM
