xs power d3400 vs. kinetiks hc2000 - Car Audio Classifieds!
Old 09-01-2011, 01:16 PM
chuck5766's Avatar
GPI Respect The Movement
0/11 sssss2191
Feedback Score: 24 reviews
Question xs power d3400 vs. kinetiks hc2000
I was wanting to know which would be better
I know the kinetiks has 100ah and the xspower has 67ah . but then the xspower has more cranking amps then the kinetiks . so which one would be better for daily ?
Thanks,
TEAM
G.P.I ..!!.. Respect The Movement ..!!..
Old 09-01-2011, 01:21 PM
wickedwitt's Avatar
Stupid Loud
0/11 sssss2394
Thanks,
Keep in mind CCA is solely a measurement to help you understand how well it will turn over a car engine, it has no bearing on prolonged high current usage that is the signature of car audio amplifiers.
That said, we kind of nee model numbers to be able to compare apples to apples. As a general rule of thumb, an XS of comparable level is better than that of a Kinetik. I would also recommend looking into Deka Intimidator series if you aren't stuck/set on just those two brands
Stupid Loud.
RidnClean's Avatar
Ballin
0/11 ssss17858
Feedback Score: 88 reviews
which batt are you comparing?
92 Ranger Walkthrough
(Under Construction)
Old 09-01-2011, 01:29 PM
chuck5766's Avatar
0/11 sssss2191
im sorry guys lols the kinetiks hc2000 vs the xspower d3400
TEAM
Old 09-01-2011, 01:31 PM
chuck5766's Avatar
0/11 sssss2191
yea i know the cranking amps are for turning the engine . but i dont understand why the xs has lower ah but higher cranking amps
TEAM
Old 09-01-2011, 01:43 PM
wickedwitt's Avatar
Stupid Loud
0/11 sssss2394
It's designed to cycle more quickly, in other words its CCA would be higher because you can draw more current from it at an instant. With those shorter cycles, however, the AH rating would be lower. The idea behind it is to have a stable charging system, then you should maintain a better voltage on the faster cycling (XS) battery.
Stupid Loud.
Old 09-01-2011, 01:48 PM
chuck5766's Avatar
0/11 sssss2191
so you say go with the xspower ?
TEAM
Old 09-01-2011, 01:50 PM
wickedwitt's Avatar
Stupid Loud
0/11 sssss2394
Given those two, yes I would choose the XS, then again in that price range I would look at Deka.
Stupid Loud.
Old 09-01-2011, 01:54 PM
Zooook's Avatar
1337 M3mb3r
0/11 sssss3991
Feedback Score: 31 reviews
i had 3 kinetik 2400s on a crescendo 3wkp and dropped quite a bit of volts, i had a saz3500 on a single xs power d3100 and id say dropped slightly less...defently xs power all the way!
ALL FOR SALE ALL FOR SALE PM ME FOR PRICES
2003 BMW 330I
2x12" AB HD/W DC XL recones
Old 09-01-2011, 01:59 PM
chuck5766's Avatar
0/11 sssss2191
ok thank you for the input man
TEAM
XS Power D3400 edouble101 Wiring, Electrical & Other Installation Equipment 2 08-21-2011 12:38 AM
Fs xs power d3400 jrplayer36 Wiring, Electrical & Other Installation Equipment 6 05-25-2011 09:05 PM
XS Power S/D3400 k3n12ock Wanting to Buy (WTB) 1 04-20-2011 03:46 AM
c&d batt or kinetiks or even xs power chuck5766 Wanting to Buy (WTB) 1 05-25-2010 07:59 PM
Xs power or kinetiks? What should I do? got160s? General Car Audio Discussion & Questions 13 03-07-2010 05:47 PM
