Air under the amp/raised amps - Car Audio Classifieds!
Old 09-02-2011, 12:26 PM
0/11 ssssss468
Default Air under the amp/raised amps
Let's say i'm building an amp rack where 2 amps will be mounted to a flat peice of wood (probably plywood) in regular horizontal position.
Do i simply screw my amps into the piece of ply or would it make sense (amps breathing) to "raise" amps up a bit so there's some air between bottom of my amps and ply.
I can achive that by glueing 8 little wooden pieces to my ply piece where amp's mouting holes are at this way i raise my amps about 1/8'' and have that 1/8'' of air under my amp
Old 09-02-2011, 12:28 PM
tacomaguy1's Avatar
0/11 sssss4401
more important to have airflow above the amp, that's where the heatsinks are
Team Flex Issues
96 Blazer
4 18" Mayhems
2 TFE 8k's
Old 09-02-2011, 12:31 PM
0/11 ssssss468
Oh yes, I know that. Reason I'm asking "under the amp" question is that i can easily do it and if there's any possible increase in "better-ness" haha I will do it.
Let's say I do my amp rack and some time later it comes out that I should have raised my amps (for whatever reason) I'll need to re-do entire thing which is not something I look forward to, I'd much rather do everything right the first time around.
Old 09-02-2011, 12:35 PM
SPY SPY is offline
0/11 ssss10192
Feedback Score: 93 reviews
I cut holes in the board I mounted the amps to to allow airflow to the bottom of the amp.
And my amps have fans on the bottom.
/ CAAA Member #2 /
Old 09-02-2011, 12:37 PM
0/11 ssssss468
Could you post a few pics for visualization purpose?
Old 09-02-2011, 12:39 PM
SPY SPY is offline
0/11 ssss10192
I didn't take any pics of that part, sorry.
/ CAAA Member #2 /
Old 09-02-2011, 12:43 PM
BKNIGHTS's Avatar
0/11 sssss2949
Feedback Score: 61 reviews
Do it. It won't hurt anything and has the possibility of helping. Even if its a tiny bit cooler.
Old 09-02-2011, 12:50 PM
tacomaguy1's Avatar
0/11 sssss4401
yeah I'd do it...every bit helps and it would suck to have to go back and do it once everything is in
Team Flex Issues
96 Blazer
4 18" Mayhems
2 TFE 8k's
Old 09-02-2011, 12:54 PM
nicholask1993's Avatar
Dubstep Addict
0/11 sssss1802
You could even use rubber grommets to help with any vibrations along with the small wooden posts.
1998 Subaru Forester
Sony CDX GT-565UP Head Unit
Cadence 6.5" Components
MB Quart Onyx 1500.1
/Surreal
Old 09-02-2011, 01:20 PM
tenbux1970's Avatar
0/11 sssss1247
My amps have cooling fans as well. Will put up pics when I get home. How big are they? What kind of auto?
Team DOA
FTMFW
raised carpet lettering littleharv93 Enclosure Discussion & Design Construction Help 18 04-02-2011 07:37 PM
velvet antler (raised eyebrow) upzaw2000 Sports and Fitness 7 01-25-2011 01:15 PM
Carpetting raised lettering, carpet keeps lifting, what HOLDS?? CleanNMean Enclosure Discussion & Design Construction Help 27 11-11-2009 09:52 AM
Opinions on amp... air circulation? ghostmechanic General Car Audio Discussion & Questions 3 07-06-2009 03:31 AM
Air Cooled Amp Box BUMPIN OLD SCHOOL Enclosure Discussion & Design Construction Help 1 06-17-2009 05:45 PM
