Enclosure for (3) SA-10's [Completed] - Car Audio Classifieds!
Old 09-03-2011, 11:27 AM
Bigbodylexus's Avatar
Saving 2nd Bass
0/11 sssss1253
Default Enclosure for (3) SA-10's [Completed]
We started talking about designing a box for 3 Sundown Audio SA-10's for the back of my 01 Camry, just curious as to what happened?
Currently I have: a 1990 Chevy Suburban with 4 Sundown Audio Zv5 18's, powered by 2 Sundown Audio SCV-7500D's. a Sundown Audio SAX-100.4 powering 4 Neo Pro 6.5's, (1) Sundown Audio SAE-50.4 on 2 ST-1 tweeters.
Trunk rattling is not a sport
Old 09-03-2011, 02:25 PM
surreal's Avatar
0/11 sssss2489
I dont honestly remembere - I am assuming it was a PM? I get a lot of PMs as you can imagine and it is hard to keep up with everything. Which is why I have the forum here as it not only showcases work but helps me keep track of designs in progress.
Did you have any further or specific questions?
Old 09-03-2011, 03:50 PM
Saving 2nd Bass
0/11 sssss1253
there were actually a few e-mails sent, I was curious as to a design they had come up with. I don't know if there was something I didn't get or perhaps you didn't get
Old 09-03-2011, 04:03 PM
Saving 2nd Bass
0/11 sssss1253
Well the max dimmensions are 40" wide, 16" high, 20" deep, subs up, port to the side
Old 09-03-2011, 05:49 PM
surreal's Avatar
0/11 sssss2489
Ill need a full design request if youre looking for it to be completed. Form is located in the sticky.
Old 09-04-2011, 03:49 PM
surreal's Avatar
0/11 sssss2489
I see your request now - It was sent to my sales e-mail. Requests normally go to [email protected]
Old 09-04-2011, 10:22 PM
surreal's Avatar
0/11 sssss2489
Posting request here for reference:
Design request for Kendrell Holley
Subwoofer/speaker brand: Sundown Audio
Subwoofer/speaker model, size, and number of woofers: SA-10, (3) D4's
Expected power handling: 600 watts each
Vehicle enclosure will be used in (please add notes if specific or unusual placement will be used): 2001 Toyota Camry
Max dimensions (MUST fit in vehicle or through trunk opening!): 40" wide, 16" high, 20" deep
Listening expectations (description): I want very good lows, trying to get to 145Db on the TL
What bandwidth is acceptable? 35-60hz high output, 30-80hz? Ignore if you do not understand 25-50Hz
How low do you want it to play and how important are the low notes (Song examples are encouraged)? I want to go to 25-30Hz with ease
Are you looking for a heavy low end, or one that blends with the rest of the output? Heavy low end
How important is sound quality compared to loudness? Sound quality is almost as equally important
Are you able to cut odd angles? (45*, 7*..) yes
Is this an SPL design? If so, what is your peak frequency? If you do not know this, please measure your average cabin length in inches! Yes, peak frequency is 4hHz
Any specific enclosure preferences (Double baffled, flush mount, center slot, blowthrough, home environment etc)? Double baffled, flush mount, subs up, port to the side
First thing is, youre shooting for 145db with three 10s, less than 2k, a camry, and want good 25hz extension.
Unless you have the mother of all rigid and sealed camry's, something has to give. Is listening impressions, or pressure numbers more important?
I am guessing listening, but Id like to confirm before moving forward with your design. I am also guessing it will be placed facing back per normal, but Id like to know this to be exact as well.
Old 09-05-2011, 09:11 PM
Saving 2nd Bass
0/11 sssss1253
Sorry about that, I actually have 3500 watts to play with, listening is ultimately the most important because I don't compete that much, I normally place the box right up against the back seat, never had one with subs up & port to the side but I would probab do that one the same way.
Old 09-06-2011, 01:37 AM
surreal's Avatar
0/11 sssss2489
Has been a fun design. The technical 3db down point should be 20-22hz or so. Should have no problems playing super low tones with the SSF down as long as you dont over power them. May be fun to play with
Design can be found/purchased here: 3xSA10s T-line enclosure - $25.00 : TheBoxHouse, Enclosure designs
Is a constant-area transmission line chosen for best efficiency within the passband and in its configuration will work well in your trunk vehicle with low end as first priority.
Enjoy!
Old 09-10-2011, 10:41 AM
0/11 ssssss759
nice design as usual ... ill be get n wit u real soon on a few ideas i got ...
The Following User Says Thank You to 918Customs For This Useful Post:
surreal (09-10-2011)
Enclosure Build: Matt's TB 10's Pioneer~Saturn Build Logs 28 08-21-2011 01:33 AM
enclosure size for 2 SDC 10's/12's blimblam General Car Audio Discussion & Questions 2 12-23-2010 09:47 PM
Sealed Enclosure for (2) 10's $10 ThumpinTitan Wiring, Electrical & Other Installation Equipment 2 12-05-2010 12:31 PM
Enclosure Build: Matt's Dual 10's Pioneer~Saturn Build Logs 9 11-05-2009 06:25 PM
