Wall enclosure plans. - Car Audio Classifieds!
Old 09-03-2011, 03:50 PM
0/11 sssssss23
Default Wall enclosure plans.
So, I'm drawing up the enclosure for my wall which is going to consist of 4 OA12d2's. I've got a box drawn up that is 7.74 cubes net (after woofer displacement and bracing, etc.) with 109 sq inches of port tuned to right around 34hz. Im curious if that is too much port for these woofers or if it should get down.
Also I'm going to be powering this with a Hifonics HiFi2500d @ 1 ohm (I know I know, cheap amp, wont do 2500, plan to upgrade when the wall is completed).
EDIT: changed a few numbers around.
Old 09-03-2011, 06:31 PM
Active Member
0/11 ssssss750
Get it down to 7.0 ft^3 after all displacement. Port area looks fine.
Old 09-03-2011, 06:42 PM
Dunbar91's Avatar
0/11 sssss6816
Feedback Score: 51 reviews
what is this going in? If its a car, why not just do 2 12's off that amp
Old 09-03-2011, 07:09 PM
0/11 sssssss23
Alrighty. Just curious to the reasoning behind 1.75 cubes per woofer instead of ~1.9 my current plans give them. Not disagreeing seeing as they're kind of your woofers and all!
Nissan 200sx. I mean, that's like telling anyone that's built a wall "Why not 2 12's?", cause they wanna get loud! I plan on running more power once the money's right anyways.
Old 09-03-2011, 07:15 PM
Dunbar91's Avatar
0/11 sssss6816
Nope, didnt know you were planning on adding power so yeah if you were not adding more power the other 2 12's would be a waste. Just cuz you have 4 under powered subs doesnt mean its going to be louder than 2 subs powered perfect, need the power behind the cone area to make it shit.
anyways, i love my obsidians so im sure you;ll be happy
Plans for a 4th Order wall grimreper912003 General Car Audio Discussion & Questions 12 01-10-2011 01:19 AM
civic hatchback-to wall or not to wall? Dbmonster Enclosure Discussion & Design Construction Help 2 12-14-2010 02:12 PM
Change in Plans Bryan General Car Audio Discussion & Questions 0 05-18-2010 12:25 PM
Weekend plans? Patrick Simmons Off Topic Chat 81 11-07-2008 10:16 PM
