Building a wall ? And Other ?'s - Car Audio Classifieds!
Old 09-04-2011, 03:46 AM
Dunder Mifflin
0/11 sssss1897
Default Building a wall ? And Other ?'s
Ok so I need to get louder like all of us usually do , couple of questions when I see walls the ports usually look really big and wide open even for like 2 -18's is it me or are they regular size next do walls usually have more cubic ft rather than a regular sub box ?
Last question or this is more of a opinion i have 1-18" aq aluminum d1 coiled sub but i really wanna do a badazz psi recone should I just buy another new aq and just smash them till they pop and send them to psi or should I try to trade my sub for some blown 18" hdc3's and some cash and send them to psi ??
Anyone design walls I'm gonna need one for 2- 18's in my 96 explorer 4dr
jordan i want my subs
Old 09-04-2011, 04:35 AM
0/11 sssssss22
walls love to be big and get loud when they are big. im doing a pair of 18s in close to 20 cubic feet. so the bigger the better. id grab another 18 and do 2 in an explorer. if you need a wall design there are plenty of places around. ram designs does and also bassheadsent.net just to name a couple.
Old 09-04-2011, 10:12 AM
Dunder Mifflin
0/11 sssss1897
What subs are you using for 20 cubes ? How do you figure port and cubes on a wall is it just the same as a regular layout
Old 09-04-2011, 10:25 AM
0/11 sssss5305
Do NOT put your HDC's in 20cubes, wall or not. Daily walls are NO different then a normal box. 12cubes net would be nice for 2 18" AQ's. I run 6 of them in my wall...
Old 09-04-2011, 01:03 PM
Dunder Mifflin
0/11 sssss1897
My 1-18" is in a 7.44 after displacement and it's pretty loud (146.4) so would I just be able to just double the cubes and port displacement ? Would 14.88 cubes work for 2-18' aq aluminum coil d1's in a wall tuned to 32ish !!!! Or could I just build to separate sides to the wall and make them 7.44 cubes each and put separate amps on each would that get loud ??
Old 09-04-2011, 06:48 PM
0/11 sssssss22
im gonna be running a pair of everest soundlabs bd 18s. actually ill be in around 16 give or take after displacement. i figured wrong before. and yes you tune the same way with a wall and a normal box
I need pointers on building a wall DevinG17 General Car Audio Discussion & Questions 4 07-05-2011 02:49 AM
thinking about building a wall now but clueless stevenminix General Car Audio Discussion & Questions 2 02-26-2011 11:25 AM
question on building a wall. osmith Enclosure Discussion & Design Construction Help 23 12-06-2010 09:44 PM
Building a wall in a 2door hatch shizzzon General Car Audio Discussion & Questions 11 09-23-2010 10:28 PM
possibly building a wall in 1st gen explorer kurrupt General Car Audio Discussion & Questions 3 09-12-2009 05:34 PM
