What do Type Rs like? - Car Audio Classifieds!
Old 09-04-2011, 11:32 AM
Matt3824's Avatar
0/11 sssss3754
Default What do Type Rs like?
It's going to be 2 Type R 12s in the back of a Nissan Xterra. Subs back port back. Just wanted to see what you guys have had good luck with as far as volume, tuning, and port area.
Old 09-04-2011, 01:01 PM
Kidthump's Avatar
Awaiting Confirmation
0/11 ssssss346
4-5 cubes, try subs up/port back, around 60-70 sq inch of port.
On tuning, that all depends on what music you listen to.
My R's seem to like 35hz.
01 Jeep Grand Cherokee Laredo 4x4
JVC KD-S26-1/0 Gauge-Audiopipe 1002
2 Obsidian 15's-Audiopipe 1500d
7 Cubes, 30hz
Old 09-04-2011, 01:26 PM
Supergumby5000's Avatar
0/11 ssssss642
depends what you're trying to do.
The easy way out is 4-5 ported @ 35hz. It'll sound like garbage, but it will get loud.
You can get a fairly flat response in a large, low tuned ported box in a small SUV like the xterra. I've also had great extension/output in a 6th order, but that may be impractical for what you want to do.
You cant go wrong in 4-5-ish @ 32-35hz if you just want some big bass.
Old 09-04-2011, 01:35 PM
RidnClean's Avatar
Ballin
0/11 ssss17858
Feedback Score: 88 reviews
my 10s were really good in [email protected]
never tried another tuning, but overall did really good in that, also had a SAZ-2500 on the pair.
92 Ranger Walkthrough
(Under Construction)
Old 09-04-2011, 01:40 PM
Kidthump's Avatar
0/11 ssssss346
Mine didn't sound like garbage, atleast i didn't think so.
7 Cubes, 30hz
Old 09-04-2011, 01:41 PM
0/11 sssss1013
right around 4 cubes, between 50 and 70 daily port, ive had good results with 100sq of port for burps. tuned around 35 to 38
on the other end of the spectrum ive also done 4 of them in around 5.5 cubes with a 60sq port tuned to 38, and it did really nice, could play down to mid 20s before dropping 3db
Team Sundown
Team XS Power
Old 09-04-2011, 01:48 PM
Kidthump's Avatar
0/11 ssssss346
Make sure you do Subs up/Port Back!
7 Cubes, 30hz
Old 09-04-2011, 02:05 PM
Nik592's Avatar
0/11 sssss2000
I ran the pre-fab B.Box from Atrend, and it killed the lows better than any one in my area with pre-fab OR custom boxes, maybe grab the specs on that box. i dont know what it was tuned to but it dropped LOOWWWWW
and still maintained that "rock punch"
sounded amazing
"Insert witty signature here"
Old 09-04-2011, 02:13 PM
Matt3824's Avatar
0/11 sssss3754
I've designed a few boxes before, and they've all impressed me. I'm still learning, but why do you say Square inches of port? Wouldn't it be cubic inches of port?
I've always heard people say to do subs back port back because the sound "bounces" off the rear hatch and gives it more ability to develop.
Old 09-04-2011, 02:18 PM
0/11 ssssss201
i have seen most people do 34-36hz but they are wishing they did 32 to hit the lows better so honestly i would go subs back port back 32hz around 4 cubes
Team Skar Audio
[SIZE=2]
'03 explorer 4.6l v8 (Legal [email protected] with 2 15" VVX on a BC2000 @.5)
New setup is underway!
WTT: Type R8" D2 for Type R12" D2 3rdshiftdiscretion Car Audio Trader (WTT) 6 08-27-2011 03:26 AM
type r 15 lincoln ls 15" Subwoofers 2 04-06-2011 04:53 PM
4 Alpine Type E 12s for a Type R 15? jakobkay Bargain Bin 13 06-01-2010 10:13 PM
WTT: 10" Dual 2 type r for 10" Dual 4 type r snoopysnooper Car Audio Trader (WTT) 2 02-08-2010 02:08 PM
