would a smaller pulley on my dc power alt improve anything ? - Car Audio Classifieds!
Old 09-04-2011, 11:57 AM
0/11 sssss1053
Default would a smaller pulley on my dc power alt improve anything ?
and where would i get one ?
i have a dc power pro series 300 amp alt and i wanted to no if a smaller pulley would do anything for my voltage ? and if so where could i get one ? i dint call dc yet to ask if they sell them.
any ideas.? thanks.
also would a external voltage modular work to increase my voltage ?
[SIGPIC] 4 15'' modded juggernauts with aluminum voice coils.. juggernauts will do 4000 rms per sub...and im swapping my 2 kicker 2500.1 amps, for a stetsom 10kd.. the rest of my system is ... 2 kicker 650.4 amps, 4 10'' evm dl10x mids. 4 8'' beyma highs. kicker kx3 3 way crossover, alpine old school digital sound field processor, over 100 feet of 0 awg flex wire and 300 amp iraggi alt, 4 deka intimidator batts...
Old 09-04-2011, 12:24 PM
98GCLimited's Avatar
0/11 sssss1921
Feedback Score: 29 reviews
I would assume a smaller pulley would spin the alt faster and deliver more amps at idle and reach the peak output of the alt at a lower rpm but only problem I would see is that it may sacrifice some bearing life. Not sure how that works with HO alts but I know thats how it works with "regular" alts.
Old 09-04-2011, 12:32 PM
RidnClean's Avatar
Ballin
0/11 ssss17858
Feedback Score: 88 reviews
i always thought DC came with smaller pulleys already?
i've had 2 other alts in, and this is smaller than those and i still need a tighter belt.
92 Ranger Walkthrough
(Under Construction)
Old 09-04-2011, 12:50 PM
profundus-sanus's Avatar
Veteran Member
0/11 sssss3026
your alt should have the correct pulley on it.
too small of a pulley could make the alt spin to fast causing the bearings to break down..
although there is always the possibility that it came with too big of a pulley causing weak out put at idle....
Old 09-05-2011, 12:26 PM
0/11 sssss1053
i could be wrong, but it looked as if the pulley on my dc pro alt was a lil bigger then my stock alt pulley.
i will go double check in my garage in a few..
Bigger or smaller to improve output? oxsign Enclosure Discussion & Design Construction Help 19 04-23-2011 07:05 PM
[TRADED] Smaller 2 ohm power volsfan92 Car Audio Trader (WTT) 17 09-13-2010 01:27 AM
Looking for a T1500-1bd new smaller power series Snwbrdr1 Wanting to Buy (WTB) 0 02-12-2009 10:08 PM
smaller pulley at idle? splvictim20 General Car Audio Discussion & Questions 43 01-05-2009 06:00 AM
