oddesey 2150s - Car Audio Classifieds!
Old 09-04-2011, 06:21 PM
0/11 sssss1380
Default oddesey 2150s
How are the oddesey 2150s? what kind of power are they good for? will hae 2 being charged with a 425a mechman alt
Team A$$hole
1998 chevy extd cab
4 SAZ 4500s
1200A of singer power
12 Fi SSDs fully loaded
[email protected]
Old 09-04-2011, 10:16 PM
98AckCL23's Avatar
0/11 sssss9929
Some of the best batts out there. Easily top 3 in the G31 class. As for power, that will be install dependent, but in Street classes for dbdrag, people have clamped over 8k (rated power from the amps) from 2 of them.
Team Concepts
Team Shok
Ohio Bass Society
Team XS Power
Old 09-04-2011, 11:16 PM
0/11 ssssss542
Yup, good batteries.
Old 09-04-2011, 11:21 PM
0/11 sssss1380
i got 2 of them for.. very cheap so im going to start with 2 for now.. hopefully have 6 or so soon..
will a single saz4500 be happy on 2 of them.. charged by a mechman 425a alt at 15.2v
Team A$$hole
1998 chevy extd cab
4 SAZ 4500s
[email protected]
Old 09-05-2011, 06:36 AM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
as said they are one of the best out there. So you should be fine. But I hope you have more then just the one alternator at 425a that thing probably won't make much at idle. And second I would avoid charging at any voltage higher than 14.7v.
Old 09-05-2011, 08:06 AM
0/11 sssss1380
Only one alt, for now i dont play anything at idle though
Team A$$hole
1998 chevy extd cab
4 SAZ 4500s
[email protected]
Old 09-05-2011, 08:35 AM
Ja Marcus
0/11 sssss6975
Music or no music at idle with just 1 alt that is a 425a unit you are gonna have voltage drop. From my experience anything over 300-350a produce very little current at low RPM. What do you need such a large alt for anyway? if you do demos most of that is done at idle. Unless you set there and rev the RPM.
Old 09-05-2011, 09:10 AM
0/11 sssss1380
i rev the truck for demos
i went with teh 425a alt becasue i plan on throwing another "smaller" one in as well for idle power,
yes the voltage drops at idle ( no music ) but thats fine
Team A$$hole
1998 chevy extd cab
4 SAZ 4500s
[email protected]
