Tower Build - Car Audio Classifieds!
Go Back   Car Audio Classifieds! > The OT™ > General Home Audio/Video
General Home Audio/Video Discuss all aspects of home audio and video here
Old 12-12-2011, 11:26 PM
0/11 ssssss576
Default Tower Build
I want to build a set of tower speaker for my Home Theater system and need a little help picking drivers. I have around 3-400 to work with and am looking for a high output SQ set-up. I have a 7.1 AV Reciever with 110 rms per channel to power them. I was thinking maybe a supertweeter or horn in each paired with some midbass/midrange drivers. I have searched parts express and madi sound, but I'm not sure exactly what I'm looking for or what would work well. Any suggestions?
bought from: hc3_cuz, iamsonic, RJRD2, zeuslicious
sold to: treylittlefield,DonH,bambino9584,mbdblue
Old 12-13-2011, 05:02 AM
C3 Customs's Avatar
0/11 sssss2446
Which Receiver are you using?
“We provide our customers the only scientific approach to musical enjoyment. ."-C3 Customs
Mobile: Bravox Audio - Stetsom - Arc Audio - Second Skin - RE Audio - Clarion - DLS - German Maestro-Bazooka
Home: Onkyo - BSA Audio - Denon - Sony - Niles Audio - DLS - Sherbourn-Velodyne-Jamo
Computer: AudioEngine
832.695.3513
Old 12-13-2011, 05:19 AM
0/11 ssssss273
Look into massive audio components, great bang for the buck. You can add an additional driver to rise the ohm load up to 8 ohms if your receiver can't handle low ohms. Make sure you also add some poly inside the enclosure if you do ported, it will just make it sound more natural.
I hope this helps, and good luck with the build.
Old 12-13-2011, 01:41 PM
0/11 ssssss576
Here is the reciever
STR-DH810 | Home Theater A/V Receiver | Sony | Sony Store USA
I will look into those, but I was more looking to use Home Audio drivers
Old 12-13-2011, 01:56 PM
Micksh's Avatar
0/11 sssss2596
You may want to go on DIYMA.com - Car Audio Forum & 12 volt Community Board and search around. There are some great reviews on raw drivers from places like Parts Express and Madisound on there. It would probably give you a pretty good idea of the direction you want to go...
My Youtube page
Astro build log link
Old 12-13-2011, 02:05 PM
0/11 ssssss576
Thanks that was very informative
would I need crossovers and if so how would I choose the right one?
Old 12-13-2011, 02:22 PM
0/11 ssssss273
Go in the DIY section in parts express and look into the drivers they use and read on about how they made the xover's for the speaker they chose.
Old 12-14-2011, 02:35 AM
C3 Customs's Avatar
0/11 sssss2446
Your power rating is based on 2 channels driven, so at any given time you may get 110wrms on any 2 channels but not all channels and the other channels may not produce any sound.
Here is an example of an amplifier that actually does its rated power on all channels:
Sherbourn PA 7-150
  • 150 watts per channel (x7) @ 8 Ohms (with no more than 0.05% THD from 20 Hz – 20 kHz, all channels driven)
  • 220 watts per channel (x7) @ 4 Ohms (with no more than 0.05% THD from 20 Hz – 20 kHz, all channels driven)
Speaker selection
Originally Posted by doctorproaudio.com
In general, the amplifier power needs to be larger than the speaker's rated power. This is because an amplifier only delivers its rated output power with sinewave signal, and delivers much less with a real signal with dynamics. As ageneral guideline, it is recommended to use an amplifier delivering 50% more power than the speaker's average ("RMS") power.
For example, for a speaker with 450W average power, an amplifier with an output of 700W may be used. If a small amplifier is used, sufficient level will not be reached, nor the perception that it is attained, so the signal will tend to be clipped to compensate, thus endangering the integrity of the speaker.
So based on the above example and your receiver specs, you should look for speakers that have an rms of 55 or less to avoid sending your speakers a clipped signal.
832.695.3513
Old 12-14-2011, 02:38 PM
0/11 ssssss576
I will be running a dc power supply to run my crescendo bc2k, and I could use my 1000c4 to power my towers if need be.
Old 12-14-2011, 02:48 PM
mcmuffin's Avatar
0/11 sssss3380
pe has a section of builds,they tell u how to make everything and even give u a parts list, id check that out
*** NEW BUILD COMING SOON ***
its a secret for now
New speaker tower build for PC 2000LaDe General Home Audio/Video 46 01-02-2012 12:10 PM
WTB: Tower Speakers for a HT MopaRBumpiN Wanting to Buy (WTB) 8 01-31-2011 10:45 PM
building a tower... cole20cole General Car Audio Discussion & Questions 8 12-29-2010 02:35 AM
In need of some beefy house tower speakers SPL_II General Home Audio/Video 15 11-30-2009 10:50 PM
Soundstream 2200 watt D-Tower Amp DNick454 CACO Amp Internals 0 10-12-2009 11:07 PM
