Hooking up factory car cd player in home - Car Audio Classifieds!
Go Back   Car Audio Classifieds! > The OT™ > General Home Audio/Video
General Home Audio/Video Discuss all aspects of home audio and video here
Old 01-05-2012, 03:28 PM
0/11 ssssss480
Default Hooking up factory car cd player in home
I'm trying to hook up my factory car player in my house to some speakers using a psu. I've seen it done on youtube but i can't seem to find the video. I'm just wondering how this would work. Thanks
Old 01-05-2012, 03:35 PM
oslouie's Avatar
0/11 sssss5073
Feedback Score: 69 reviews
You'll have to find out the wiring diagram for your factory radio. You'll also have to find a way to plug wires into those pins where the harness used to be. After that, all you need is a 12 volt power supply.
Sent from my EVO 3D using Tapatalk
Old 01-05-2012, 03:37 PM
0/11 ssssss480
Yeah that's the problem I am having. Idk where to wire them at or how to get the PSU and cd player connected. It would be a lot easier if it was an aftermarket stereo but that's in my car lol.
Old 01-05-2012, 03:59 PM
oslouie's Avatar
0/11 sssss5073
You'll have to figure that one on your own. I'm limited to internet access (phone). It's more trouble than It's worth.
Old 01-05-2012, 07:01 PM
SPLpizzaguy's Avatar
Humbled by CACO
0/11 sssss3110
Feedback Score: 57 reviews
chop of harness.
Get a wiring guide for your car via internet.
Hook up power and grounds. If pcu for a crazy reason does not have a ground hook it to the ground loop on an outlet in your house.
Actually simple
Make sure to cut wires long in case you ever need to hook factory unit back up.
If your going to do it, go all out. Get a big vertical battery charger and hook it up in your basement. You get subs,amps,speakers,and headunit.
4 sa10s
Taramps 8k
4 American Bass VFL 6.5s
Ohio Generator 305 amp alt
4 Vifa Tweets.
Old 01-06-2012, 02:30 AM
0/11 ssssss480
Originally Posted by SPLpizzaguy View Post
chop of harness.
Actually simple
This is a factory cd player so there is no harness unless it's inside it and I have to take the back apart. I'm not really sure...
Old 01-08-2012, 09:53 PM
Humbled by CACO
0/11 sssss3110
Ebay a factory harness for your car then. The male harness should fit into the back of cd player. I bought one for a honda was 4.95
4 sa10s
Taramps 8k
4 Vifa Tweets.
Old 01-08-2012, 09:59 PM
Bologna's Avatar
Ad ministrator
0/11 sssss2872
Pizza guy, I'm not sure if that would work? Or I don't understand you correctly...
You just hook your 12v car battery up to a battery charger and use that?
Refs: BlackWaterOp x2, Master69 x3, Scottie x3, RidnClean, JusBlaze (Scammed Me), SPLaudio x3, ltr450racer690, dbeez, LuisT, SPY, Mgcauctions09 x3, pieper88 x3, scottyk, Jh8909, JB312, stretch, Mechman, 01SpyderDB23, andrewtexas123, 50 black guys, bubbagumper6, btr, SacTownBully84
Old 01-08-2012, 10:26 PM
Humbled by CACO
0/11 sssss3110
Don't even need to use a battery just plug in the charger to your wall and turn it on. Hook the wires from the back of the cd player from harness that u need to buy to the charger.
I've had one in my buddys camper for last 5+ years. It slams on the lake.
4 sa10s
Taramps 8k
4 Vifa Tweets.
Old 01-08-2012, 10:52 PM
its_ray_ray's Avatar
OCD Member
0/11 sssss5696
Feedback Score: 23 reviews
I used a 12v power source. If wanting to use a amp n subs also make sure you get a decent supply of juice to properly run a CD player and amp off it. My dad used them all the time to test/run cb's from inside the house.
Sent from your mom's phone.
hooking up home amp?????s scfaust General Home Audio/Video 11 01-21-2013 04:03 PM
Can Home MLV be used in my car? SPLpizzaguy Sound Deadening & Fabrication 2 04-10-2011 11:31 PM
How To- Hooking up a second battery in your car SPL Guru Tutorials & Quick References 1 09-30-2008 01:00 PM
How to: Hooking up a car sub to your home theatre or computer SPL Guru Tutorials & Quick References 10 08-20-2008 09:04 AM
