Need some suggestions for custom Dayton powered sub build - Car Audio Classifieds!
Go Back   Car Audio Classifieds! > The OT™ > General Home Audio/Video
General Home Audio/Video Discuss all aspects of home audio and video here
Old 03-09-2012, 10:12 AM
0/11 sssssss60
Default Need some suggestions for custom Dayton powered sub build
I have experience with building boxes for cars but not much for houses. I have no idea how much space to give the sub or what to tune it to so any help or suggestions would be much appreciated.
Equipment:
15" Dayton Audio Reference HO RSS390HO-4
500 watt Dayton plate amp
2 4" Precision aero ports 15.5" max length each
I will be building this out of 3/4" MDF (already have 2 half sheets). The sub is only going to be used for listening to music (mostly rap). The room is 12' wide 20' long 8' high with cement floor and drywall walls.
Old 03-18-2012, 05:39 PM
0/11 ssssss226
Parts Express has that sub and this question was asked, there.
Best cabinet for home use?
Someone recommended this enclosure, and one of the staff members agreed.
Dayton Audio SWC-3CO 3.0 ft³ Subwoofer Cabinet with Cutouts
Mimic that box and it should do well for you.
eBay Username -
Old 03-18-2012, 06:23 PM
0/11 ssssss226
I got bored so I figured one up using BassBox 6 Pro
Using the "High Fidelity" suggestion . . .
3.175 cu/ft
Fb = 29.85Hz
F3 = 31.46
1 Top, 1 Bottom: 30" x 19", 0.75"
1 Front, 1 Back: 11" x 17.5", 0.75"
2 Sides: 11" x 30" x 0.75"
Vent Parts
1 Port: 4" x 11"
Box Properties
Name:
Type: Vented Box
Shape: Prism, square
Vb = 2.937 cu.ft
Fb = 29.85 Hz
QL = 6.637
F3 = 31.46 Hz
Fill = none
No. of Vents = 1
Vent shape = round
Vent ends = two flared
Dv = 4 in
Lv = 11 in
I used these T/S parameters from the spec sheet.
http://www.parts-express.com/pdf/295-469s.pdf
Type: Standard one-way driver
Company: Dayton Loudspeaker Co.
Serial No: 0000000
Comment:
No. of Drivers = 1
Fs = 24.2 Hz
Qms = 4.48
Vas = 109.7 liters
Cms = 0.11 mm/N
Mms = 380.6 g
Rms = 13.35 mohms
Xmax = 12 mm
Xmech = 18 mm
P-Dia = 12.86 in
Sd = 829.6 sq.cm
P-Vd = 995.5 cu.cm
Qes = 0.42
Re = 3.3 ohms
Le = 1.83 mH
Z = 4 ohms
BL = 21.52 Tm
Pe = 800 watts
Qts = 0.384
no = 0.357 %
1-W SPL = 87.67 dB
2.83-V SPL = 91.52 dB
eBay Username -
Old 03-20-2012, 05:04 AM
0/11 sssssss60
Thanks for the suggestions guys... I got some idea's off AVS forums and this is what I ended up with.
Now I just need to build the second one!
Build review/suggestions? klrsrt General Car Audio Discussion & Questions 1 02-02-2012 01:08 PM
Suggestions on new build TheJesus General Car Audio Discussion & Questions 45 08-13-2009 10:06 PM
Suggestions? for a build mytyeerinpie General Car Audio Discussion & Questions 46 12-24-2008 05:19 AM
Dayton Concours d'Elegance at Carillon Park ~ Dayton OH ~ 09-14-2008 Patrick Simmons Car Show Feeds 0 09-12-2008 02:27 AM
Dayton Concours d'Elegance at Carillon Park ~ Dayton OH ~ 09-14-2008 Patrick Simmons Car Show Feeds 0 09-11-2008 02:20 PM
