Need Projector HDMI help please... - Car Audio Classifieds!
Go Back   Car Audio Classifieds! > The OT™ > General Home Audio/Video
General Home Audio/Video Discuss all aspects of home audio and video here
Old 07-27-2012, 11:18 PM
SINTORMAN's Avatar
157.28db,41hz +Increasing
0/11 sssss4907
Feedback Score: 17 reviews
Default Need Projector HDMI help please...
Been trying to research this but my results have been not very helpful. I have a optoma HD20 projector and a computer with a 4890. I think with a recent update my hdmi output is no longer compatible with the projector... please tell me there is an easy fix for this?
Should I try to just install outdated drivers for my card?
Projector does work with older hdmi sources.
And I cannot find the supposed firmware downloads for the hd20...
help please ...
Current Build:
#60sHereIcome
Old 07-27-2012, 11:44 PM
SPL Distribution Owner
0/11 sssss2983
i wouldnt see how that could happen...
All video cards i know of have only 2 RAMDACs but 3 outputs per card...
Go into your display properties where you change cloning, etc.. and see if it sees your projector even plugged up. If it does not, unplug the HDMI cable, then plug it back in.
If connected or using dual monitors, try unplugging the AUX one and see if it then finds your projector.
If it does not, go into Catalyst settings and see if it picks up your projector anywhere.
IF it does not, somewhere in the Catalyst settings will allow a feature to FORCE Detect for displays. I would enable this at that point.
Old 07-27-2012, 11:54 PM
SINTORMAN's Avatar
0/11 sssss4907
Not even detected.. Used to be detected as optoma projector. But now nothing. Tried forced detection. No dice.
Doesn't work with my dads computer either when it used too. he has like a 5k ati card. I have tried all that.
Gonna try DNA drivers next. Then just outdated drivers.
Current Build:
#60sHereIcome
Old 07-28-2012, 01:06 AM
SINTORMAN's Avatar
0/11 sssss4907
tried some more stuff... reverted back to 11.8 and 11.10 and no dice... beginning to think something is wrong with projector... even though it still works with my cowon v5 using hdmi input.
Could something have "happened" internally to make computers not respond to it?
Current Build:
#60sHereIcome
Old 07-28-2012, 01:11 AM
0/11 sssss3842
Try a diff hdmi cord?
93 Ford Explorer
4 SA12s
2 saz 1500Dv1 strapped @ 1ohm
saz 100.4
4 sets of IA components
Mechman 260a Alt
Custom door panels
Old 07-28-2012, 01:12 AM
SINTORMAN's Avatar
0/11 sssss4907
tried 3 and 1 that I know works because I use it with said cowon.
Current Build:
#60sHereIcome
Old 07-28-2012, 01:46 AM
0/11 sssssss80
have you recently changed the bulb in the p/j? i had an old p/j i changed the bulb in and it threw it out of wack to were they were saying i had to send it in for them to update something in it. the problems with it was i could turn it on, but if i changed sources or turned it off and tried to turn it on later it wouldnt come on. as far as the drivers can you roll them back?
try calling the card manufacturer and see what they have to say about the update and what changes were made from the working driver.
Old 07-28-2012, 01:54 AM
SINTORMAN's Avatar
0/11 sssss4907
projector still plays fine though... And I did go back to my previous drivers which were working with the projector..guess something is messed up in the projector
What would cause it to work with my cowon v5 but not my comp?
Current Build:
#60sHereIcome
Old 07-28-2012, 02:58 AM
SINTORMAN's Avatar
0/11 sssss4907
tried some more testing. Cowon on 1 hdmi in and ps3 on the other.. Got the ps3 to recognize (won't alone either like my comp) but the image that came up was a still frame of half the video image off the cowon and purple static.
So what does the cowon have differently than the hdmi out on my comp and ps3?
Would clipping pin 13 fix this?
***I don't think it is related but I got this projector for free from an apartment that flooded. It was under water but when I got it I used a food dehydrator to dry it out and it has been working for over a year. I am not sure what else changed. Maybe switching OS's was just a coincidence.
Current Build:
#60sHereIcome
Old 07-28-2012, 07:23 AM
profundus-sanus's Avatar
Veteran Member
0/11 sssss3026
sounds like something went in the projector and the cowon just has the most lenient communication protocols..
toyota corolla projector and headlight t.hybrid Miscellaneous Stuff For Sale 0 10-15-2011 09:55 PM
Dlp projector with mount marcmdm2005 Miscellaneous Stuff For Sale 12 06-16-2011 04:06 PM
hdmi problem korey_hofer General Home Audio/Video 6 01-10-2011 05:44 PM
Projector Problems mytyeerinpie General Automotive Chat 27 04-27-2009 06:51 AM
hdmi natisfynest Off Topic Chat 1 02-14-2009 07:41 PM
