55" LCD TV/Harmon Kardon receiver lil help - Car Audio Classifieds!
Go Back   Car Audio Classifieds! > The OT™ > General Home Audio/Video
General Home Audio/Video Discuss all aspects of home audio and video here
Old 10-09-2012, 09:01 PM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
Default 55" LCD TV/Harmon Kardon receiver lil help
I bought my tv recently and now I wanna start getting my surround sound hooked up. With the sub and plate amp in the garage still, no build for them yet, i got my surround speakers already mounted. Question is: not very many outputs on back of the tv, not as many as the rear projection tv I had. The back of the HK receiver has a bunch of RCA outs/ins. How do I go about hooking up the surround sound to listen to tv or even a dvd blu ray? I have quick charts for the HK but at the moment I have no idea where it is. If someone could tell me step by step, I'd appreciate it.
Old 10-09-2012, 09:40 PM
jwright0291's Avatar
Big Ballin
0/11 sssss1468
Feedback Score: 23 reviews
Your tv should have an audio out, use rcas from that to your receiver. Hook everything else to your tv. Then all your audio from your tv will play thru ur receiver on all inputs. Make sense? Is that what you needed?
Old 10-09-2012, 09:52 PM
Matt3824's Avatar
0/11 sssss3754
Most modern TVs only have a digital (optical) out. If it's any decent HK it has an optical in. This is what you use if you have cable TV that just goes directly to the coax on the back of the TV. If you have something that has a seperate box, such as DirecTv or Dish, you want to use RCA or preferably optical if available. You can also use the HDMI for audio. RCA<HDMI<Optical for sound
Old 10-09-2012, 09:54 PM
0/11 ssss12531
Well not really. Which RCA's do I plug them into? I got many choices like Video in/out like 4 of these combined, dvd, etc. HK model AVR 240. I currently have Dish Network. And using the side HDMI cable for the tv.
Old 10-09-2012, 09:58 PM
Big Ballin
0/11 sssss1468
Do you have any HDMI devices or just composite RCA
Old 10-09-2012, 10:02 PM
Big Ballin
0/11 sssss1468
What devices do you have and what model tv?
Old 10-09-2012, 10:30 PM
0/11 ssss12531
Have like 4 HDMI outputs on Vizio tv E552VLE
Old 10-09-2012, 10:40 PM
Big Ballin
0/11 sssss1468
What devices do you have to hook up?
Old 10-10-2012, 11:12 AM
Big Ballin
0/11 sssss1468
Hopefully this helps,
Old 10-10-2012, 12:51 PM
Matt3824's Avatar
0/11 sssss3754
Yep^ Just like that. If you have more than 3 devices, use component. It's picture really isn't noticeably different from HDMI
7" lcd monitors x2 jdmferio13 Head Units, Processors & EQs 32 10-29-2011 06:26 AM
old school harmon kardon xjoeyc23x eBay 0 06-11-2011 03:35 PM
marine pyramid 6s, harmon kardon mid bass/ tweets sleepingciv Other Size subwoofers 1 03-23-2011 08:52 PM
Will wiring 4 ohm sub to 8 ohm home receiver blow the receiver up? tahoebrotha General Car Audio Discussion & Questions 6 12-01-2008 06:07 PM
