Need some n00bie HT help - Car Audio Classifieds!
Go Back   Car Audio Classifieds! > The OT™ > General Home Audio/Video
General Home Audio/Video Discuss all aspects of home audio and video here
Old 01-17-2014, 09:57 PM
jwright0291's Avatar
Big Ballin
0/11 sssss1468
Feedback Score: 23 reviews
Default Need some n00bie HT help
So my roommate brought his Pioneer VSX-818V and a couple towers from home to hook up in our living room. Hooked that all up fine and dandy..well this past weekend he brought his Sony SA-W2500 Active sub. I hooked the power up and ran a RCA from the sub to the preout on the receiver and it plays a constant tone..somewhat like a constant 35hz tone...and doesn't stop unless I unplug the RCA. ANY ideas?
Old 01-17-2014, 10:47 PM
whitetrash84's Avatar
0/11 ssssss125
Bad RCA?
Old 01-17-2014, 10:53 PM
e46inperrycounty's Avatar
SPL Farms
0/11 sssss5706
I'd guess rca or bad ground on the outlet you plugged into. Possibly getting more like a 60hz tone from the outlet? Could also be that the preout is putting out the wrong voltage forthe sub, or a bad signal, or the powered sub could have something wrong with the board..
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 01-22-2014, 11:08 PM
Big Ballin
0/11 sssss1468
Switched RCA and still did it. It doesn't make a good connection in the socket either so Im sure that isn't helping the problem. Probably something wrong with the board I suppose
Old 01-22-2014, 11:24 PM
xnewbx's Avatar
0/11 ssssss985
Mine does the same thing IF there's no music already playing. Mine sounds like a 60hz tone which could be bad ground idk. But if I play even the slightest music it completely stops the tone.
I know it's no solution but maybe help you I some way lol
Edit: it does it if the device isn't sending a signal to it at the time
Example: if my laptop is plugged into it and the laptop goes to sleep it will start buzzing so I would imagine RCA related
