quick H/T subwoofer question - Car Audio Classifieds!
Go Back   Car Audio Classifieds! > The OT™ > General Home Audio/Video
General Home Audio/Video Discuss all aspects of home audio and video here
Old 10-22-2009, 04:08 AM
0/11 ssssss165
Default quick H/T subwoofer question
I have a 15" laying around I was thinking about using for H/T but was wondering if an "under powered" 15" would be better than say a decently powered 10"... kind of a dumb question I am sure but...
the 15" can take 2K+ daily with ease... the 10" is rate for like 800W~, I want to tune around 34hz~ or so I think and I have about 1Kw of power to work with...
Old 10-22-2009, 04:11 AM
silvercookie's Avatar
0/11 sssss1945
do the 15 in a very low tuned extremely big box.
super efficient.
Old 10-22-2009, 04:48 AM
0/11 ssss31247
it will work well
Old 10-22-2009, 04:55 AM
dak446's Avatar
0/11 sssss5914
tune lower for home theatre
Old 10-22-2009, 09:07 AM
nismos14's Avatar
Super Moderators
0/11 ssss18243
Feedback Score: 64 reviews
Definitely worth it, you need the low end impact that a larger driver can provide over the output a 10 that needs less power would need. A large ported box tuned down low around 20hz would be great.
My Car, My Ears.
Old 10-22-2009, 09:48 AM
RollerDJ's Avatar
Plays With Fire
0/11 ssss10067
this, i noticed a huge difference between the pair of 10's i was using and the 18 i'm using now. BUT, just how much room can you deicate to the box? if your tight on space, then the 10 would be a better woofer. better to have the 10 in a properly tuned and sized box than a 15 in something to small.
Proud Member of CAAA!
Old 10-22-2009, 01:20 PM
0/11 ssssss165
welll, depends on how "BIG" big is in home theater boxes...
I have a solid 10ft^3 net to work with behind the entertainment center which is where I would like it. would an aero port wrok with said setup?
Old 10-22-2009, 01:25 PM
RollerDJ's Avatar
Plays With Fire
0/11 ssss10067
thats more than enough. mine was 4ft^3 @27 hz. was a nice blend for HT and music. if you have that much room, i'm now a beliver in T-lines when you have the room. your going to use much more room than a standard ported box. as far as aero port, i'm not sure if you have any port noise when your tuning that low. i did a slot port and never heard anything but bass.
Old 10-22-2009, 01:48 PM
0/11 ssssss165
I know nothing about T-lines to be honest. slot port and aero port I can do but that is about it... LOL
I am planning to use some PC power supplies (I know a lot of peopel think this is "ghetto" but...) to power the amp and had a question about them as well. After looking around it seems the higher the wattage the power supply is the more amperage it can put out. I have found some 1Kw power supplies and was thinking I would run a pair of them in series.
The specific ones I am am looking at have the fallowing outputs: Output: +3.3V @ 30A; +5V @ 30A; +12V1 @ 20A; +12V2 @ 20A; +12V3 @ 25A; +12V4 @ 25A; -12V @ 0.8A; +5VSB @ 6.0A... since I will be using all four of the +12v outputs to go to the amp will that indeed give me 90A or am I mixed up here? I found them for $20/ea so I figured buy two just to be safe. For the time being the amp I have is a Sony (2 X 40A fuses) and will be running at 4ohm putting out 500~ rms, I will be getting a 1ohm stable amp that puts out 1Kw-1.5Kw once I get it all hooked up and tested out...
Old 10-22-2009, 01:50 PM
RollerDJ's Avatar
Plays With Fire
0/11 ssss10067
i've seen people do that. i'd honesly look into some rack mount amps. there are some decent deals on the bay from time to time. it'll be a much cleaner look, and less parts to wire, or fail on you.
Quick Sub Temp Question Bologna General Car Audio Discussion & Questions 15 10-09-2009 09:49 AM
Quick question... Answer QUICK please its getting dark soon Sonically_Sound General Car Audio Discussion & Questions 11 10-03-2009 08:41 PM
Quick Question... MysticStyl3z General Car Audio Discussion & Questions 5 07-07-2009 12:24 PM
Quick Question 350zkid General Car Audio Discussion & Questions 10 04-15-2009 04:28 PM
Quick question. rdaudioman1256 General Car Audio Discussion & Questions 3 11-16-2008 01:09 PM
