Impedance Rise- Polyfil, Sealed vs. Ported, Bracing - Car Audio Classifieds!
Go Back   Car Audio Classifieds! > CACO Car Audio Clubs > Car Audio Clubs > Georgia SPL
Old 12-30-2010, 10:10 PM
Awaiting Confirmation
0/11 sssssss94
Default Impedance Rise- Polyfil, Sealed vs. Ported, Bracing
Okay so, I am planning on building my box tomorrow and I want to clear some things up before I start..
Impedance rise, how can I keep it to a minimum?
I know that good bracing keeps impedance rise down via reducing the resonant freq. of the box. What about polyfil? Also, ported vs. sealed, which tends to yield a lower rise?
Thank you!
Michael
Vehicle.: 1999 Infiniti QX4
HU......: Alpine CDA-9884 (80PRS coming soon)
Comps...: Stock........ (MS-62c's coming soon)
Sub.....: None........ (DMAX15v4D2 coming soon)
2ch Amp.: Alpine3554 (RA320.2 coming soon)
Sub Amp.: None........ (CT1400.1 coming soon)
Old 12-30-2010, 10:17 PM
murderedtahoe's Avatar
Mr. Low End Monster
0/11 sssss3512
i wouldn't worry about rise that much for daily driving system. if your really concern about getting maximum power from your amp. i would get an very stout amp and wire @ .5 ohms nominal after imp rise it will still be low enough to start getting decent power from your amp or amps.
Old 12-30-2010, 10:29 PM
Novicaine's Avatar
CACO Late Night Crew
0/11 sssss6135
Yea and even if u had an amp that was weaker then an underrated amp, it won't be noticeable anyway. Imp rise dosnt matter for music it is natural.
Bracing is good, but dosnt lower res freq. You can say it reduces the build resonance or something though which is great.
Old 12-30-2010, 10:38 PM
FatBoy2's Avatar
That was crafty.
0/11 sssss1790
Impedance rise is still an important factor, even in a daily application.
If your impedance rises to say... 2.5 ohms on a 40hz test tone. Then you'll see the same rise on a 40hz note. (but you are correct, it's constantly changing)
And bracing (in my case, atleast) has contributed to my impedance rise.
Fo eights in da pickup!
Old 12-30-2010, 10:41 PM
if you get rid of impedance rise alot of people will start blowing subs left and right
Old 12-30-2010, 10:42 PM
FatBoy2's Avatar
That was crafty.
0/11 sssss1790
^ And amplifiers.
Old 12-30-2010, 10:46 PM
Mr. Low End Monster
0/11 sssss3512
oh yea op, bracing will actually worsen imp rise. the smaller the enclouser the more imp rise. so adding bracing will do what?
Old 12-30-2010, 10:47 PM
Mr. Low End Monster
0/11 sssss3512
lol and its plenty of that going on now!
Old 12-30-2010, 10:58 PM
Highs On Bass's Avatar
I'm F*CKIN Sexy!
0/11 sssss2132
if you want to help, it... with strength, and not add bracing , do some resin.
will also help with airflow, as long as its VERY smooth. and help with it as well..
also make sure contact points are secure, and are properly connected.
sodder makes a great conductor, and wiring. larger wire usually helps with at least your starting imp. depending on the length. also make sure that EACH run of wire both pos and NEG are the same.
those are things I've done to help. doesn't stop imp rise. but helps.
Yep... I'm an AMI NUT HUGGER>.. HE's the master of my wood
Current scores to date as of 12/5/2010:
Sealed 152.9
Outlaw 156.6
Old 12-30-2010, 11:15 PM
FatBoy2's Avatar
That was crafty.
0/11 sssss1790
Resin alone would be about as effective as squeezing the enclosure with your hands, for bracing. Resin alone is terrible for bracing. But it seals and smooths.
Impedance rise Bigbodylexus (Sundown Audio) 6 11-16-2010 12:20 PM
impedance rise AND Win ISD..... rawlins87 General Car Audio Discussion & Questions 7 08-07-2010 10:56 PM
question about impedance rise Craig28 General Car Audio Discussion & Questions 11 07-16-2010 02:54 PM
box and impedance rise MiX General Car Audio Discussion & Questions 20 05-26-2010 06:31 PM
calculating impedance rise? F3M4 General Car Audio Discussion & Questions 4 07-15-2009 10:27 PM
